FCP Cropping Image (confusing)
I am putting a 720×486 (DVCPRO HD 720p60codec)into a DVCPRO HD 720p60 960×720 sequence. When I do the image is the right aspect ratio, but it is getting cropped – alot. It’s like a 720×486 piece of the image scaled up to fill the space that the whole image should be in. Even if I scale it down, it still remains cropped on the right side and bottom. I am also putting pillar bars on to fill the sides. The bars are one targa file (864×488 square). If I put this file above the 720×486 file in the sequence, nothing happens except now there are pillar bars. BUT when I turn the composite mode of the pillar bars targa to anything but Normal, the entire 720×486 image below it (which was cropped) is is visible how it should be.
Yes I do have scale clips to sequence checked.
