FCP crashing within minutes (with 2x CRASH REPORTS)
Hello kind forum,
FCP crashes so often I can barely do a minute worth of work before it crashes again. Sometimes I don’t even touch it and it crashes before I can begin work. In addition, I can’t nest a sequence or export to quicktime. I have edited plenty of stuff on this set up so I am not sure what is wrong. This is very strange.
I am editing a 25 minute sequence. It has some VFX stuff but nothing too complex. The footage was shot on a Sony Z7 (HDV1080/50i).
I am using a…
iMac11,3, 4 processors, Intel Core i7, 2.93 GHz, 16 GB, SMC 1.59f2
Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MBThe crashing began happening on the occasional ‘auto save’. I then turned off the auto save function and began saving as often as possible. (NOTE: each time FCP crashed, I would start up the project from an ‘auto saved’ file and then rename it. This resulted in the render files being scattered across several folders – could this be an issue? Also, before attempting the first ‘nest sequence’ I created a duplicate sequence as a back-up – this is when the crashing really started getting worse.)
Please help.
Thanks in advance.
Below are the 2 latest crash reports.
LATEST CRASH REPORT
Process: Final Cut Pro [282]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 6.0.6 (6.0.6)
Build Info: FCP
Code Type: X86 (Native)
Parent Process: launchd [118]Date/Time: 2012-05-31 10:25:15.404 +1000
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6Interval Since Last Report: 1854392 sec
Crashes Since Last Report: 45
Per-App Interval Since Last Report: 1253303 sec
Per-App Crashes Since Last Report: 40Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000002b
Crashed Thread: 0 Dispatch queue: com.apple.main-threadApplication Specific Information:
objc_msgSend() selector name: retainThread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x91a93f87 objc_msgSend + 23
1 com.apple.QuickTime 0x93b6a542 ICMEncodedFrameCreateMutable + 187
2 com.apple.AppleHDVCodec 0x0ebc0df6 MPEG2CompressorComponentDispatch + 12132
3 com.apple.AppleHDVCodec 0x0ebc8a6a MPEG2CompressorComponentDispatch + 43992
4 com.apple.AppleHDVCodec 0x0ebc92f7 MPEG2CompressorComponentDispatch + 46181
5 com.apple.AppleHDVCodec 0x0ebbfc42 MPEG2CompressorComponentDispatch + 7600
6 com.apple.AppleHDVCodec 0x0ebc086f MPEG2CompressorComponentDispatch + 10717
7 com.apple.AppleHDVCodec 0x0ebbd9be MPEG2DecompressorComponentDispatch + 12536
8 com.apple.AppleHDVCodec 0x0ec39f31 0xebb8000 + 532273
9 …ple.CoreServices.CarbonCore 0x97329dcc CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
10 com.apple.AppleHDVCodec 0x0ebbdf07 MPEG2CompressorComponentDispatch + 117
11 …ple.CoreServices.CarbonCore 0x9732251f CallComponentDispatch + 29
12 …ple.CoreServices.CarbonCore 0x973228a8 CallComponentClose + 43
13 …ple.CoreServices.CarbonCore 0x973227d1 CloseComponentInternal(ComponentInstanceRecord*) + 101
14 …ple.CoreServices.CarbonCore 0x97322752 CloseComponent + 46
15 …alCutPro.Plugins.QTM Reader 0x0db8de91 LongGOPCompressionSession::close() + 47
16 …alCutPro.Plugins.QTM Reader 0x0db8385b AudioExtractor::~AudioExtractor() + 33485
17 …alCutPro.Plugins.QTM Reader 0x0db89487 PluginMainEntry(long, long, KGDictInt*, void*) + 8299
18 com.apple.FinalCutPro 0x0022cb21 ExportClipCore(KGDictInt*, long, KGDictInt*, KGDictInt*, KGFileSpec*, long, unsigned char) + 3651
19 com.apple.FinalCutPro 0x00232e2f pKGExportClip(KGDictInt*, long) + 857
20 com.apple.FinalCutPro 0x001a2857 pKGMenuPerformExport(KGDictInt*, long) + 99
21 com.apple.FinalCutPro 0x000a7d00 pKGClipHandleDefaultMenu(KGDictInt*, long, unsigned char) + 1172
22 com.apple.FinalCutPro 0x001cc1d7 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 865
23 …Pro.Plugins.Timeline Editor 0x0dc13c46 DisposeMenuStrings() + 47570
24 com.apple.FinalCutPro 0x0029c556 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 1800
25 com.apple.FinalCutPro 0x0024b803 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 109
26 com.apple.FinalCutPro 0x0024cce1 TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 101
27 com.apple.FinalCutPro 0x002923fd pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
28 com.apple.FinalCutPro 0x002a71ef pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 93
29 com.apple.FinalCutPro 0x0014a072 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 444
30 com.apple.FinalCutPro 0x0014a1dd HandleCommand(long, unsigned char, unsigned char, unsigned char) + 251
31 com.apple.FinalCutPro 0x004005ca CommandProcess(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 362
32 com.apple.HIToolbox 0x91eddc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
33 com.apple.HIToolbox 0x91edcef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
34 com.apple.HIToolbox 0x91eff7f3 SendEventToEventTarget + 52
35 com.apple.HIToolbox 0x91f2be87 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
36 com.apple.HIToolbox 0x91f50b90 SendMenuCommandWithContextAndModifiers + 66
37 com.apple.HIToolbox 0x91f50b47 SendMenuItemSelectedEvent + 121
38 com.apple.HIToolbox 0x91f50a5d FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
39 com.apple.HIToolbox 0x91f20160 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 454
40 com.apple.HIToolbox 0x920d2936 MenuSelect + 190
41 com.apple.HIToolbox 0x9208b8e0 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 92
42 com.apple.HIToolbox 0x91ede22b HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 173
43 com.apple.HIToolbox 0x91eddc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
44 com.apple.HIToolbox 0x91edcef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
45 com.apple.HIToolbox 0x91eff7f3 SendEventToEventTarget + 52
46 com.apple.HIToolbox 0x91f113ef ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1417
47 com.apple.HIToolbox 0x91ede080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
48 com.apple.HIToolbox 0x91edcef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
49 com.apple.HIToolbox 0x91eff7f3 SendEventToEventTarget + 52
50 com.apple.HIToolbox 0x92088c17 ToolboxEventDispatcher + 86
51 com.apple.HIToolbox 0x92088d4f RunApplicationEventLoop + 243
52 com.apple.FinalCutPro 0x0014cece KGMainEvent(void*) + 46
53 com.apple.FinalCutPro 0x002aae53 main + 59
54 com.apple.FinalCutPro 0x00003122 _start + 216
55 com.apple.FinalCutPro 0x00003049 start + 41Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x94da1382 kevent + 10
1 libSystem.B.dylib 0x94da1a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x94da0f59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x94da0cfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x94da0781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x94da05c6 start_wqthread + 30Thread 2: com.apple.CFSocket.private
0 libSystem.B.dylib 0x94d99ac6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x9aa55c53 __CFSocketManager + 1091
2 libSystem.B.dylib 0x94da8259 _pthread_start + 345
3 libSystem.B.dylib 0x94da80de thread_start + 34Thread 3:
0 libSystem.B.dylib 0x94d7ab42 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x94da86f8 _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x94df105f pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x004292ad Synchronizable::Wait() + 47
4 com.apple.FinalCutPro 0x004152e8 DisplayQueue::Run() + 702
5 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x94da8259 _pthread_start + 345
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 4:
4 com.apple.FinalCutPro 0x004cc3e3 WorkUnitPerformer::Run() + 55
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 5:
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 6:
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 7:
0 libSystem.B.dylib 0x94d7aafa mach_msg_trap + 10
1 libSystem.B.dylib 0x94d7b267 mach_msg + 68
2 com.apple.CoreFoundation 0x9aa162df __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x9aa153c4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x9aa1b304 CFRunLoopRun + 84
5 com.apple.DVCPROHDMuxer 0x0f5930fb AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 297
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 8:
4 com.apple.CoreFoundation 0x9aa151f1 CFRunLoopRunInMode + 97
5 ….CoreMediaIOServicesPrivate 0x010459ab MIO::DAL::RunLoop::OwnThread(void*) + 157
6 ….CoreMediaIOServicesPrivate 0x0104781c CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x94da8259 _pthread_start + 345
8 libSystem.B.dylib 0x94da80de thread_start + 34Thread 9:
0 libSystem.B.dylib 0x94d7ab5a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x94da86e1 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x94dd75a8 pthread_cond_timedwait_relative_np + 47
3 …ple.CoreServices.CarbonCore 0x97301b90 TSWaitOnConditionTimedRelative + 242
4 …ple.CoreServices.CarbonCore 0x973018ce TSWaitOnSemaphoreCommon + 511
5 …ickTimeComponents.component 0x99f52d25 ReadSchedulerThreadEntryPoint + 4698
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 10:
5 …ple.CoreServices.CarbonCore 0x9735c5aa AIOFileThread(void*) + 1127
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 11:
3 com.apple.AppleProResDecoder 0x4db61a4b IcpDecompressorComponentDispatch + 1771
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 12:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 13:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 14:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 15:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 16:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 17:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 18:
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 19:
0 libSystem.B.dylib 0x94da8aa2 __semwait_signal + 10
1 libSystem.B.dylib 0x94da875e _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x94daa3f8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.AppleVADriver 0x4e5b71dc AVAGetRendererInfo + 7404
4 com.apple.AppleVADriver 0x4e5bcc2f AVAGetRendererInfo + 30527
5 libSystem.B.dylib 0x94da8259 _pthread_start + 345
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 20:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 21:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 22:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 23:
5 …ple.CoreServices.CarbonCore 0x97325b8b TimerThread + 97
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 24:
3 …ickTimeComponents.component 0x9a0c1165 jpegdecompress_MPLoop + 79
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 25:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 26:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 27:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 28:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 29:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 30:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 31:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 32:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 33:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 34:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 35:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 36:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 37:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 38:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 39:
5 com.apple.DesktopServices 0x979dfb3d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
6 …ple.CoreServices.CarbonCore 0x972e154a PrivateMPEntryPoint + 68
8 libSystem.B.dylib 0x94da80de thread_start + 34Thread 40:
1 libSystem.B.dylib 0x94dd49c5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x94dd4903 usleep$UNIX2003 + 61
3 com.apple.AppKit 0x90d3ce2d -[NSUIHeartBeat _heartBeatThread:] + 2039
4 com.apple.Foundation 0x9270f4c4 -[NSThread main] + 45
5 com.apple.Foundation 0x9270f474 __NSThread__main__ + 1499
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 41:
0 libSystem.B.dylib 0x94da0412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x94da09a8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x94da05c6 start_wqthread + 30Thread 42:
2 libSystem.B.dylib 0x94da05c6 start_wqthread + 30Thread 43:
3 com.apple.AppleHDVCodec 0x0ec3bfc8 0xebb8000 + 540616
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 44:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 45:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 46:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 47:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 48:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 49:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 50:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 51:
3 com.apple.AppleHDVCodec 0x0ec3d371 0xebb8000 + 545649
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 52:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 53:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 54:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 55:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 56:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 57:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 58:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x8a4a4610 ebx: 0x9a9e004d ecx: 0x913693e0 edx: 0x0000000b
edi: 0x8a4a4610 esi: 0x8a4a4610 ebp: 0xbfff7be8 esp: 0xbfff7bc8
ss: 0x0000001f efl: 0x00210282 eip: 0x91a93f87 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x0000002bPREVIOUS CRASH REPORT
Process: Final Cut Pro [203]
Build Info: FCP
Parent Process: launchd [118]Date/Time: 2012-05-31 10:06:33.670 +1000
Report Version: 6Interval Since Last Report: 1853265 sec
Crashes Since Last Report: 44
Per-App Interval Since Last Report: 1252351 sec
Per-App Crashes Since Last Report: 39Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000f89f06a0
Crashed Thread: 52Thread 0: Dispatch queue: com.apple.main-thread
3 com.apple.AppleHDVCodec 0x0eee508d MPEG2CompressorComponentDispatch + 160251
4 com.apple.AppleHDVCodec 0x0eec71de MPEG2CompressorComponentDispatch + 37708
5 com.apple.AppleHDVCodec 0x0eec87d3 MPEG2CompressorComponentDispatch + 43329
6 com.apple.AppleHDVCodec 0x0eec9231 MPEG2CompressorComponentDispatch + 45983
7 com.apple.AppleHDVCodec 0x0eebfab2 MPEG2CompressorComponentDispatch + 7200
8 com.apple.AppleHDVCodec 0x0eebd8ff MPEG2DecompressorComponentDispatch + 12345
10 com.apple.AppleHDVCodec 0x0eebdf07 MPEG2CompressorComponentDispatch + 117
12 com.apple.QuickTime 0x93d4a27e ImageCodecCompleteFrame + 49
13 com.apple.QuickTime 0x93b68e8e icmCompressionSessionCompleteFramesUpToDisplayNumberAndDisplayTimeStamp + 167
14 com.apple.QuickTime 0x93b6c47f ICMCompressionSessionCompleteFrames + 374
15 …alCutPro.Plugins.QTM Reader 0x0de80e5f LongGOPCompressionSession::flush() + 59
16 …alCutPro.Plugins.QTM Reader 0x0de76613 AudioExtractor::~AudioExtractor() + 32901
17 …alCutPro.Plugins.QTM Reader 0x0de7c487 PluginMainEntry(long, long, KGDictInt*, void*) + 8299
18 com.apple.FinalCutPro 0x00454b1b RenderToFile(KGFileRec*, unsigned char, KGDictInt*, double, double*, char*, unsigned long long, KGRenderBitFlags, unsigned long, LongGopConformParameters*) + 643
19 com.apple.FinalCutPro 0x00464db6 RenderOneFile(KGDictInt*, double, double*, unsigned long*, long, long, KGDictInt*, KGItemSpec*, char*, unsigned long long, unsigned long, KGRenderCancelHandling, KGPlayerRec*, KGRenderBitFlags, unsigned char, KGFileSpec*, unsigned char*, unsigned char, LongGopConformParameters*, std_vector*) + 3736
20 com.apple.FinalCutPro 0x0047a994 PlayerRenderHelp(KGPlayerRec*, double, double, char*, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, unsigned char, KGRenderBitFlags) + 4570
21 com.apple.FinalCutPro 0x0047d98e pKGPlayerRender(KGPlayerRec*, double, double, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, KGRenderBitFlags) + 4918
22 com.apple.FinalCutPro 0x000a9077 pKGClipHandleDefaultMenu(KGDictInt*, long, unsigned char) + 6155
23 com.apple.FinalCutPro 0x001cc1d7 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 865
24 …Pro.Plugins.Timeline Editor 0x0df0cc46 DisposeMenuStrings() + 47570
25 com.apple.FinalCutPro 0x0029c556 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 1800
26 com.apple.FinalCutPro 0x0024b803 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 109
27 com.apple.FinalCutPro 0x0024cce1 TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 101
28 com.apple.FinalCutPro 0x002923fd pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
29 com.apple.FinalCutPro 0x002a71ef pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 93
30 com.apple.FinalCutPro 0x0014a072 HandleMenuCommand(long, unsigned char, unsigned char, unsigned char, KGErrorCode (*)(long, long, KGDictInt*, void*), void*) + 444
31 com.apple.FinalCutPro 0x0014a1dd HandleCommand(long, unsigned char, unsigned char, unsigned char) + 251
32 com.apple.FinalCutPro 0x0014fbe5 HandleKeyDown(OpaqueEventRef*, KGDictInt*, KGWindowRec*) + 1423
33 com.apple.FinalCutPro 0x001519fd DoEvent(OpaqueEventRef*, KGDictInt*) + 2971
34 com.apple.FinalCutPro 0x004000fd Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 69
35 com.apple.HIToolbox 0x91eddc2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
36 com.apple.HIToolbox 0x91edcef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
37 com.apple.HIToolbox 0x91edcd55 SendEventToEventTargetWithOptions + 58
38 com.apple.HIToolbox 0x91f1160b ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1957
39 com.apple.HIToolbox 0x91ede080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
40 com.apple.HIToolbox 0x91edcef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
41 com.apple.HIToolbox 0x91eff7f3 SendEventToEventTarget + 52
42 com.apple.HIToolbox 0x92088c17 ToolboxEventDispatcher + 86
43 com.apple.HIToolbox 0x92088d4f RunApplicationEventLoop + 243
44 com.apple.FinalCutPro 0x0014cece KGMainEvent(void*) + 46
45 com.apple.FinalCutPro 0x002aae53 main + 59
46 com.apple.FinalCutPro 0x00003122 _start + 216
47 com.apple.FinalCutPro 0x00003049 start + 41Thread 1: Dispatch queue: com.apple.libdispatch-manager
5 com.apple.DVCPROHDMuxer 0x0f97f0fb AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 297
3 com.apple.AppleProResDecoder 0x4df03a4b IcpDecompressorComponentDispatch + 1771
4 libSystem.B.dylib 0x94da8259 _pthread_start + 345Thread 11:
3 com.apple.vImage 0x95a396ec vImageQueue_DequeueJob + 44
4 com.apple.vImage 0x95a397ec vImageWorkerThreadFunc + 124
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 19:
7 libSystem.B.dylib 0x94da80de thread_start + 34Thread 22:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 23:
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 24:
4 com.apple.FinalCutPro 0x0008f6bf SyncMetaDataTask::GetNextEvent() + 81
5 com.apple.FinalCutPro 0x00090e5f SyncMetaDataTask::Run() + 39
6 com.apple.FinalCutPro 0x00453544 Thread::RunHelper(void*) + 20
8 libSystem.B.dylib 0x94da80de thread_start + 34Thread 30:
3 com.apple.AppleVADriver 0x57f7d1dc AVAGetRendererInfo + 7404
4 com.apple.AppleVADriver 0x57f82c2f AVAGetRendererInfo + 30527
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 31:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 40:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 41:
6 libSystem.B.dylib 0x94da80de thread_start + 34Thread 42:
3 com.apple.AppleHDVCodec 0x0ef3bfc8 0xeeb8000 + 540616
5 libSystem.B.dylib 0x94da80de thread_start + 34Thread 43:
