Activity › Forums › Apple Final Cut Pro Legacy › FCP crashing while rendering
  • FCP crashing while rendering
    Posted by Amit Ghildiyal on July 6, 2009 at 4:28 pm
    I am rendering out 1 hour nested sequences at broadcast settings.
    DV/DVCPRO NTSC, 29.97, MEDIUM quality, sound 16 bit 48 khz, prepped for streaming. For some reason, FCP is crashing while rendering. I never had this problem before.
    I have checked my seq settings too,
    dv/ntsc 3:2,
    field dom: lower
    Pixel aspect is NTSC CCIR 601
    compressor: dv/dvcpro ntsc
    Kindly help
    Amit Ghildiyal replied 17 years, 3 months ago 2 Members · 2 Replies
  • David Bogie
    July 6, 2009 at 4:30 pm
    Does it crash at the same place?
    If so, you’ve got some bad media at that point.
    Any CMYK Photoshop files or still images?
    bogiesan
  • Amit Ghildiyal
    July 6, 2009 at 5:00 pm
    no stills, only the text layers, but i have always used them and renders have been fine. The only thing i can think of is that I had saved the same file with 2 names, one”old” and the other “final” in the same place with the same scratch disk and render file location. I deleted the “old” fcp file ( not the cache files) one to avoid confusion. but it shouldnt have made a difference as the other “final” file was saved and was the only one i was working on.
