Activity Forums Apple Final Cut Pro Legacy FCP crashing when adding a clip to timeline.
  • FCP crashing when adding a clip to timeline.
    Posted by Olivier Aubut on October 14, 2009 at 1:33 pm
    Hi guys
    I’ve been having crashing issues for quite some time now. FCP keeps crashing, at least once a day. It seems to happen when I drag a clip from the viewer to the timeline.
    I’m working exclusively with multiclips on this project so I don’t know if the crashing still occurs on normal clips.
    It happens randomly, but always when I’m dragging a clip to the timeline and I can’t reproduce the crash, so I’m ruling out the “bad clip” possibility. I’ve tried trashing my prefs.
    I’m running FCP 6.0.6
    OSX 10.5.8 on an octo 3.2 GHz with 8 GB of RAM, Kona LH
    Dvcpro HD on a G-Speed XL connected through Fiber Channel.
    Here’s a link to the crash report: 327_fcpcrashreport.rtf.zip
    Any help is much appreciated. I’m starting to show signs of carpal tunnel syndrome hitting command-s every 30 seconds. 😉
    Olivier
    Olivier Aubut replied 16 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • Tom Wolsky
    October 14, 2009 at 3:20 pm
    What OS is this? What version of QuickTime?
    It could be a hardware issue.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Olivier Aubut
    October 14, 2009 at 3:32 pm
    Thanks Tom
    Quicktime is version 7.6.4 and Kona LHe driver version is 6.0.2.
    Olivier
  • Tom Wolsky
    October 14, 2009 at 4:10 pm
    The OS, the operating system?
    All the best,
    Tom
  • Olivier Aubut
    October 14, 2009 at 4:14 pm
    10.5.8, Leopard.
  • Tom Wolsky
    October 14, 2009 at 4:43 pm
    You might want to contact AJA, but I think it may be a hardware problem on the computer, RAM or processor.
    All the best,
    Tom
  • Steve Knattress
    October 14, 2009 at 4:44 pm
    How big is your project?
    I did some multicam work (9 xdcam dvcam) when my project size got larger ( more than 100Mb) I experienced many crashes.
    Try and trim your project and see if the crashes still happen?
    I found that just doing a “save-as” and deleting sequences etc. does not work.
    You need to make a new project and transfer sequences etc into it.
    Steve
  • Olivier Aubut
    October 14, 2009 at 4:51 pm
    Thank you Tom
    I’ll try to uprade to the latest Kona driver, and if that doesn’t help I’ll contact AJA.
    Olivier
  • Olivier Aubut
    October 14, 2009 at 4:58 pm
    Thanks for your help Steve.
    This particular project is only 13 MB, but I’ve had problems before with projects bigger than 100MB as well.
    I should start a new thread for this but have you had the chance to work with multiclips on FCP7? Is it more stable?
    Olivier
