Activity Forums Apple Final Cut Pro Legacy fcp crashing on export or render
  • fcp crashing on export or render
    Posted by Vu Thai on June 28, 2010 at 7:27 am
    i have a short 10min clip that has been crashing everytime i try to export. i have trashed prefs and that doesn’t work. i’m using fcp 6. the annoying part is that everytime it crashes it takes over 1/2 hour to read the project to open the file. all my files are stored on a firewire harddrive. is there anything i can do to make it faster?
    also i have a timelapse of jpg images on my sequence, is this causing it to crash? each image is jpb and rgb settings.
    Ben Halsall replied 16 years, 1 month ago 3 Members · 5 Replies
  • Rafael Amador
    June 28, 2010 at 2:54 pm
    [vu thai] “lso i have a timelapse of jpg images on my sequence, is this causing it to crash?”
    Even if that is not the reason of the crashing, FC will be much happier without a bunch of JPEGs on top.
    rafael
    http://www.nagavideo.com
  • Vu Thai
    June 28, 2010 at 3:12 pm
    so i should just change them to tiffs?
  • Rafael Amador
    June 28, 2010 at 3:52 pm
    Hi Vu,
    Any Bit Map format (PNG, TIFF, TGA,..) will make the things easier for FC.
    rafael
  • Vu Thai
    June 28, 2010 at 5:48 pm
    i changed all images to tiff and it’s still crashing. any ideas?
  • Ben Halsall
    July 28, 2010 at 9:56 am
    Final Cut should handle JPEGs. I’d try exporting out sections of the film by setting in and out points on the timeline. Try two minute sections at first then stitching these back together. There is probably one dodgy image that is messing things up.
