Activity Forums Blackmagic Design FCP Crashes with BMD 5.7b1 drivers…
  • FCP Crashes with BMD 5.7b1 drivers…
    Posted by Matt Geller on August 27, 2006 at 4:54 pm
    We are getting consistent crashes when trying to load still images (not too large but larger than NTSC screen size) into the Viewer. This is on Dual 2Ghz G5s running Extreme SD PCI-X cards with the following software:
    FCP 5.1.1
    QT 7.1.2
    OS 10.4.7
    BMD 5.7b1
    Downgrades to 5.6.2 drivers alleviate the issue.
    Matt Geller
    Meta Media
    Dan Sparks replied 20 years ago 3 Members · 6 Replies
  • Kristian Lam
    August 29, 2006 at 1:55 am
    Hi Matt,
    Thanks. I think we should have a fix for this very soon as we’ve managed to replicate this.
    regards
    Kristian Lam
    Blackmagic Design
  • Dan Sparks
    August 29, 2006 at 2:51 pm
    Matt,
    Have you found a work-around to this problem? And is it only with specific types of stills, or is it all still images? I’m just starting a project and it will require the use of still images supplied by the client.
    Dan Sparks
    Tricom Video
  • Matt Geller
    August 29, 2006 at 4:38 pm
    The fix currently is to downgrade (via uninstall and reinstall) of 5.6.2 drivers.
    Cheers,
    Matt
    Matt Geller
    Meta Media
  • Dan Sparks
    August 29, 2006 at 5:24 pm
    Will those 5.6.2 drivers work with my Mac Pro?
    Dan Sparks
    Tricom Video
  • Matt Geller
    August 30, 2006 at 4:54 am
    Unforunately the 5.7 beta drivers are the minimum for Mac Pros. BMD is aware of the issue. Make sure Kristian knows of your fate.
    Matt Geller
    Meta Media
  • Dan Sparks
    August 30, 2006 at 5:02 pm
    I’ve been in touch with Kristian. They’re working on it. Thanks for getting back to me.
    Dan Sparks
    Tricom Video
