Activity Forums Blackmagic Design FCP crashes when outputting to BM
  • FCP crashes when outputting to BM
    Posted by Jan Van den bossche on May 22, 2007 at 9:36 pm
    hi,
    i have a MacPro(3gigProcessor, 4 gig RAM) with FCS1 and multibridge pro and since this morning every file I import into FCP makes the program crash when I press play. My Video Playback settings are set to BM RGB. When I change these settings to Firewire everything is ok again…so I can’t use my video output through my decklink card anymore cause it makes FCP to crash! I installed the 6.2 drivers tonight but it makes no difference.
    thank you
    Jan
    Belgium
    Jan Van den bossche replied 19 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jan Van den bossche
    May 23, 2007 at 6:23 am
    And now the MacPro won’t even start up anymore when my multibridge device is connected. When I pull out the power off my multibridge Pro, everything is ok…but now I can’t work with BM anymore, grrr ;o)
  • Jekabs
    May 25, 2007 at 9:13 am
    Do you have Black Magic Multibride or Black Magic Declink Extreme card?
    If Declink Extreme, then they have a very serious bug which they promised to be fixed in 6.2 driver version, but it is still there in 6.2.
    The bug is 2 GB RAM limit.
    It means that if you want to work with FCP and BM Deck Link you must take out 2 GB of your memory and wait until they’ll fix this bug.
    Good luck
    Jekabs
    May 25, 2007 at 11:19 am
    hey,
    I have a Multibridge Pro system, so… it will be another problem, thanks anyway.
    The system preferences on my Macpro recognize the Multibridge, but I can’t get any video in or out via the multibridge. If I use firewire, then everything works perfectly, but I’d like to use the Multibridge of course ;o)
  • Jekabs
    May 25, 2007 at 12:07 pm
    Strange.
    I also have the same mac as yours and the same card. But everything works fine form me and i even have 6 GB of RAM.
    The only difference is that i work with 6.1 drivers.
    Try to uninstal 6.2 and go back to 6.1. Maby it helps.
  • Evan Thomas phillips
    May 29, 2007 at 6:22 pm
    I have a multi-bridge and the same problems. I tried uninstalling the 6.2 drivers and going back to the 6.1 drivers, and it didn’t help. Maybe it has something to do with firmware?
    May 30, 2007 at 6:06 pm
    hi,
    after mailing with the people from BM, we concluded that the Multibridge hardware has to be replaced.
    June 1, 2007 at 12:12 am
    Like, take the PCIe card out and put it back in, or like buying a new Multibridge? Is BM willing to replace the unit free of charge?
    June 1, 2007 at 7:10 am
    well, they should replace the unit cause you do get a few years guarantee, so I guess it’s normal! They asked me the name of the reseller and they would arrange everything, but I didn’t get any response since tuesday, so I’m waiting… i’ll keep you posted
