Activity Forums Apple Final Cut Pro Legacy FCP Crashes; Unexpectedly Quits Way Too Much
  • FCP Crashes; Unexpectedly Quits Way Too Much
    Posted by Jas L. on November 24, 2006 at 2:22 pm
    Hello Gurus 😉
    Hmmm didnt’ have this issue with any G5 but ever since the Mac Pro has been in the picture and recently applied the new EFI Firmware, FCP is driving the system up the walls. It just quits. EFI is the only last major thing can think of (but it could be coincidence). The EFI Update rebooted when it was 80% complete but in system it shows everything being OK and noticed couple others had the same EFI process too.
    Sometimes, it will let you scrub the sequence(s) (we have 5 in a project) and then all of sudden DIE or sometimes after re-starting as soon as you click on a sequence tab, dead!
    I understand it could be corrupted clips but its just 3 long clips editied down and we have checked them over. Some of the other things that are in the project that others have had issues with include motion projects on timeline and boris title 3d that we are using. Tried doing that didn’t work. The basics, trash prefs etc. have already been applied. Interesting enough, Safari also freezes from time to time. Wonder if its hardware issue. Crash log is posted below and I have no idea what Thread 0 reads 🙂
    Also, some of the things I would like to try:
    a) Where is the Apple Hardware Test Utility?
    b) On Intel Macs, what is the name or can download a memory testing utility to check my RAM chips. I belive it was free but I forget the name but I used it once on the g5 to check and see if RAM is good
    c) Anything else that I should try??? (other than Re-install system or is that the best thing at this point)
    System: MacPro 3.0GHz, 4 GB (2GB Apple, 2GB Crucial), Kona Card, Medea FCR with Apple HBA (not Atto), FCP 5.1.2
    Thank You guys; this has sure got my brains going crazy.
    Much Appreciated
    Jas
    Crash Log:
    Date/Time: 2006-11-24 05:47:41.052 -0500
    OS Version: 10.4.8 (Build 8L2127)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [81]
    Version: 5.1.2 (5.1.2)
    Build Version: 3
    Project Name: FCPApp
    Source Version: 609211640
    PID: 467
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 0 Crashed:
    0 <<00000000>> 0x00000000 0 + 0
    1 com.apple.motion.filters 0x28bb491c Effect_CanUseFragmentProgram(char const*) + 26
    2 com.apple.motion.filters 0x28bbfdc9 -[GaussianBlur initResources] + 51
    3 com.apple.motion.filters 0x28bfbe0a -[SoftFocus initResources] + 80
    4 com.apple.motion.filters 0x28bfaa64 -[SoftFocus initWithAPIManager:] + 42
    5 …uartzComposer.FxPlugWrapper 0x08d703e8 0x8d6e000 + 9192
    6 com.apple.QuartzComposer 0x9748d9df +[GFNode nodeWithIdentifier:] + 98
    7 com.apple.ProFX 0x00c6c665 -[PFXNodeManager nodeInstanceWithName:] + 113
    8 com.apple.FinalCutPro 0x004b30bf PatchForEffectDict(KGDictInt*) + 291
    9 com.apple.FinalCutPro 0x004b536c FCPQCMainEntry(long, long, KGDictInt*, KGFileRec*) + 3182
    10 com.apple.FinalCutPro 0x002b6030 pKGRunTransition(KGDictInt*) + 2064
    11 com.apple.FinalCutPro 0x00223893 GetFilterFrame(KGDictInt*, KGClipItemType, long, unsigned char, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 3541
    12 com.apple.FinalCutPro 0x002281ef GetMotionFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 12461
    13 com.apple.FinalCutPro 0x00228d1c GetBlurFrame(KGDictInt*, KGClipItemType, WhenRec*, double, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*, unsigned char*) + 2642
    14 com.apple.FinalCutPro 0x0022a1f1 GetTrackItemFrame(KGDictInt*, TrackInfoRec*, BufferInfoRec*, KGCanvasRec*, KGRect*, renderStackInfo*) + 5317
    15 com.apple.FinalCutPro 0x00220733 CompositeLoop(KGDictInt*, WhenRec*, KGCanvasRec*, KGRect*, BufferInfoRec*, renderStackInfo*, unsigned char*, TrackItemAtTimeCache*) + 1319
    16 com.apple.FinalCutPro 0x0022ba51 pKGGetClipVideoWithAlpha(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, AlphaType*, unsigned long long) + 5019
    17 com.apple.FinalCutPro 0x0021e2ec pKGGetClipVideo(double, long, KGCanvasRec*, KGRect*, long, KGDictInt*, unsigned long long) + 80
    18 …alCutPro.Plugins.QTM Reader 0x0651c3be AudioExtractor::~AudioExtractor [in-charge deleting]() + 23190
    19 …alCutPro.Plugins.QTM Reader 0x06522f32 PluginMainEntry(long, long, KGDictInt*, void*) + 6964
    20 com.apple.FinalCutPro 0x0041d8d7 RenderToFile(KGFileRec*, unsigned char, KGDictInt*, double, double*, char*, unsigned long long, KGRenderBitFlags, unsigned long, LongGopConformParameters*) + 643
    21 com.apple.FinalCutPro 0x0042db90 RenderOneFile(KGDictInt*, double, double*, unsigned long*, long, long, KGDictInt*, KGItemSpec*, char*, unsigned long long, unsigned long, KGRenderCancelHandling, KGPlayerRec*, KGRenderBitFlags, unsigned char, KGFileSpec*, unsigned char*, unsigned char, LongGopConformParameters*, std_vector*) + 3710
    22 com.apple.FinalCutPro 0x004373e1 PlayerRenderHelp(KGPlayerRec*, double, double, char*, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, unsigned char, KGRenderBitFlags) + 3951
    23 com.apple.FinalCutPro 0x00445bdc pKGPlayerRender(KGPlayerRec*, double, double, char*, unsigned long long, KGRenderCancelHandling, unsigned char*, KGRenderBitFlags) + 4612
    24 com.apple.FinalCutPro 0x001a62bb AutoRenderClips(KGListRecord*, unsigned char, unsigned char*) + 197
    25 com.apple.FinalCutPro 0x001a6b92 AutoRenderTimer(long, long, KGDictInt*, void*) + 828
    26 com.apple.FinalCutPro 0x00139a7f KGIdleTimerInvoke(__EventLoopTimer*, unsigned short, void*) + 127
    27 com.apple.HIToolbox 0x92f23a27 IdleTimerVector + 68
    28 com.apple.CoreFoundation 0x90829822 CFRunLoopRunSpecific + 3341
    29 com.apple.CoreFoundation 0x90828b0e CFRunLoopRunInMode + 61
    30 com.apple.HIToolbox 0x92dd7bef RunCurrentEventLoopInMode + 285
    31 com.apple.HIToolbox 0x92dd72fd ReceiveNextEventCommon + 385
    32 com.apple.HIToolbox 0x92e1fc8f _AcquireNextEvent + 58
    33 com.apple.HIToolbox 0x92e1fad0 RunApplicationEventLoop + 150
    34 com.apple.FinalCutPro 0x0013cfb4 KGMainEvent(void*) + 46
    35 com.apple.FinalCutPro 0x0028dccf main + 59
    36 com.apple.FinalCutPro 0x00002fc6 _start + 228
    37 com.apple.FinalCutPro 0x00002ee1 start + 41
    Thread 1:
    0 libSystem.B.dylib 0x90024427 semaphore_wait_signal_trap + 7
    1 com.apple.FinalCutPro 0x003f3187 Synchronizable::Wait() + 47
    2 com.apple.FinalCutPro 0x003e0702 DisplayQueue::Run() + 702
    3 com.apple.FinalCutPro 0x0041c27c Thread::RunHelper(void*) + 20
    4 libSystem.B.dylib 0x90023d87 _pthread_body + 84
    Thread 2:
    0 libSystem.B.dylib 0x90037697 mach_wait_until + 7
    1 …ple.CoreServices.CarbonCore 0x90ce1621 Delay + 118
    2 …dgiantsoftware.deartifacter 0x0891c97a RGS::SerialServer::ThreadProcess() + 54
    3 …ple.CoreServices.CarbonCore 0x90cb3f84 PrivateMPEntryPoint + 51
    Thread 3:
    2 com.apple.FinalCutPro 0x00492c7d WorkUnitPerformer::Run() + 55
    Thread 4:
    Thread 5:
    Thread 6:
    0 libSystem.B.dylib 0x90009857 mach_msg_trap + 7
    1 com.apple.CoreFoundation 0x908292f3 CFRunLoopRunSpecific + 2014
    2 com.apple.CoreFoundation 0x9083a1c8 CFRunLoopRun + 60
    3 com.apple.DVCPROHDMuxer 0x2c016507 AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 285
    Thread 7:
    3 com.apple.AVCVideoServices 0x00c15df1 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 149
    Thread 8:
    2 com.apple.CoreFoundation 0x90828b0e CFRunLoopRunInMode + 61
    3 com.apple.audio.CoreAudio 0x9146341e HALRunLoop::OwnThread(void*) + 158
    4 com.apple.audio.CoreAudio 0x91463239 CAPThread::Entry(CAPThread*) + 93
    5 libSystem.B.dylib 0x90023d87 _pthread_body + 84
    Thread 9:
    0 libSystem.B.dylib 0x90048a47 semaphore_timedwait_signal_trap + 7
    1 …ple.CoreServices.CarbonCore 0x90cdd0ab TSWaitOnSemaphoreCommon + 163
    2 …ickTimeComponents.component 0x97dc3992 ReadSchedulerThreadEntryPoint + 4895
    3 libSystem.B.dylib 0x90023d87 _pthread_body + 84
    Thread 10:
    0 libSystem.B.dylib 0x900268bc kevent + 12
    1 …ple.CoreServices.CarbonCore 0x90cb3f84 PrivateMPEntryPoint + 51
    2 libSystem.B.dylib 0x90023d87 _pthread_body + 84
    Thread 11:
    1 …ple.CoreServices.CarbonCore 0x90cb4129 MPWaitOnQueue + 198
    2 com.apple.DesktopServices 0x9251cb5b TNodeSyncTask::SyncTaskProc(void*) + 143
    Thread 12:
    1 com.apple.vImage 0x91c59d9d vImageQueue_DequeueJob + 104
    2 com.apple.vImage 0x91c59ff4 vImageWorkerThreadFunc + 113
    Thread 13:
    Thread 14:
    Thread 15:
    2 …ple.CoreServices.CarbonCore 0x90ce6ff0 AIOFileThread(void*) + 1068
    Thread 16:
    1 …ple.CoreServices.CarbonCore 0x90ce73ce MPWaitOnSemaphore + 152
    2 …ickTimeComponents.component 0x982146ab DecompressFramesMPTask + 120
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0x92b0cb23 ecx: 0x07fbc420 edx: 0x02576600
    edi: 0xa2b0c00c esi: 0xbfff8b70 ebp: 0xbfff8b98 esp: 0xbfff8b6c
    ss: 0x0000001f efl: 0x00010246 eip: 0x00000000 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    Binary Images Description:
    0x1000 – 0x69afff com.apple.FinalCutPro 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xa19000 – 0xa1efff com.apple.proapps.ProTimecode 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/ProTimecode.framework/Versions/A/ProTimecode
    0xa26000 – 0xa6dfff com.apple.proapps.MIO 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0xa9d000 – 0xaa0fff KGCore /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xaa7000 – 0xab8fff com.apple.AERegistration 1.2 (58.2) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xac7000 – 0xacefff com.apple.AEProfiling 1.2 (14.2) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xad6000 – 0xae7fff com.apple.framework.promedia.ProMediaIOUnit 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIOUnit.framework/Versions/A/ProMediaIOUnit
    0xc05000 – 0xc26fff com.apple.AVCVideoServices 1.0 (32) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xc3f000 – 0xc47fff com.apple.framework.promediaio 1.0.0 (1) /Applications/Final Cut Pro.app/Contents/Frameworks/ProMediaIO.framework/Versions/A/ProMediaIO
    0xc4e000 – 0xcc1fff com.apple.ProFX 1.1 /Library/Frameworks/ProFX.framework/Versions/A/ProFX
    0x19d4000 – 0x19d5fff com.apple.FinalCutPro.Plugins.Text Window 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0x1a92000 – 0x1a93fff com.apple.FinalCutPro.Plugins.Vector Accelerator 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0x1af5000 – 0x1af9fff com.apple.FinalCutPro.Plugins.AudioGroupsExport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0x1d6c000 – 0x1d97fff com.apple.FinalCutPro.Plugins.AfterEffects 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0x1d9f000 – 0x1db6fff com.apple.FinalCutPro.Plugins.AudioMixer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0x1dc3000 – 0x1dd7fff com.apple.proapps.ControlSurfaceSupport 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0x1ded000 – 0x1df2fff com.apple.FinalCutPro.Plugins.Cache Manager 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0x1df6000 – 0x1dfafff com.apple.FinalCutPro.Plugins.LayerFileReader 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0x1f05000 – 0x1fb3fff com.apple.FinalCutPro.Plugins.Browser 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0x1fc8000 – 0x1fdffff com.apple.FinalCutPro.CinemaTools 3.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0x1fe9000 – 0x1ff4fff com.apple.FinalCutPro.Plugins.CTHelper 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0x61bb000 – 0x61dffff com.apple.FinalCutPro.Plugins.EditTape 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0x61ed000 – 0x6232fff com.apple.FinalCutPro.Plugins.EDL Export 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0x6246000 – 0x624efff com.apple.FinalCutPro.Plugins.Effect Builder 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0x6252000 – 0x625dfff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0x6265000 – 0x6298fff com.apple.FinalCutPro.Plugins.FCS Engine 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0x62a1000 – 0x62b2fff com.apple.FinalCutPro.Plugins.FilterCustomEd 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0x62b6000 – 0x62cafff com.apple.FinalCutPro.Plugins.FilterViewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0x62ce000 – 0x62ecfff com.apple.FinalCutPro.Plugins.Flash 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0x62fb000 – 0x6307fff com.apple.FinalCutPro.Plugins.GenViewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0x630b000 – 0x6355fff com.apple.FinalCutPro.Plugins.Media Manager 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0x6360000 – 0x6364fff com.apple.FinalCutPro.Plugins.MolokiniSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0x6369000 – 0x637dfff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0x638a000 – 0x639efff com.apple.FinalCutPro.Plugins.Motion Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0x63a2000 – 0x63bdfff com.apple.FinalCutPro.Plugins.Movie Analyzer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0x63cb000 – 0x63d9fff com.apple.FinalCutPro.Plugins.Movie Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0x63dd000 – 0x63e1fff com.apple.FinalCutPro.Plugins.NuggetExport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0x63e5000 – 0x649dfff com.apple.FinalCutPro.Plugins.OMF Audio Export 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0x64b9000 – 0x64c2fff com.apple.FinalCutPro.Plugins.Perf Analyzer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0x64c6000 – 0x64d8fff com.apple.FinalCutPro.Plugins.ProAppsIntegration 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0x64e5000 – 0x64f2fff com.apple.FinalCutPro.Plugins.Pulldown Support 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0x64f8000 – 0x6533fff com.apple.FinalCutPro.Plugins.QTM Reader 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0x653e000 – 0x6546fff com.apple.FinalCutPro.Plugins.QuickView 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0x654a000 – 0x6557fff com.apple.FinalCutPro.Plugins.Relink Media 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0x655b000 – 0x65d5fff com.apple.FinalCutPro.Plugins.Timeline Editor 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0x65de000 – 0x65e5fff com.apple.FinalCutPro.Plugins.Transcoder 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0x65ea000 – 0x65fbfff com.apple.FinalCutPro.Plugins.Transition Viewer 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0x65ff000 – 0x6614fff com.apple.FinalCutPro.Plugins.Trimming 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0x6618000 – 0x661ffff com.apple.FinalCutPro.Plugins.VDUSupport 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0x6624000 – 0x6635fff com.apple.FinalCutPro.Plugins.VideoLog 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0x6639000 – 0x6651fff com.apple.FinalCutPro.Plugins.VoiceOver 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0x6656000 – 0x66b4fff com.apple.FinalCutPro.Plugins.XML Support 5.1.2 /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0x71fc000 – 0x7218fff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver
    0x7265000 – 0x7268fff com.apple.LiveType.component 2.1.2 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x726d000 – 0x72d2fff com.apple.LiveType.framework 2.1.2 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x72fa000 – 0x72fdfff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x7302000 – 0x7317fff com.apple.fcp.DVOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0x74c8000 – 0x7621fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x764d000 – 0x783bfff com.apple.ATIRadeonX1000GLDriver 1.4.40 (4.4.0) /System/Library/Extensions/ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
    0x7877000 – 0x789bfff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x78aa000 – 0x78bcfff com.apple.FCP Uncompressed 422.component 1.4 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x7950000 – 0x796ffff com.aja.kona.codec 3.2 /Library/QuickTime/KonaCodec.component/Contents/MacOS/KonaCodec
    0x79e7000 – 0x7a2bfff com.apple.DVCPROHDCodec 1.3 (228) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x7a40000 – 0x7a94fff com.apple.AppleHDVCodec 1.2 (206) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x7a9d000 – 0x7ab6fff com.apple.AppleIntermediateCodec 1.1 (141) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0x7abb000 – 0x7adafff com.apple.IMXCodec 1.2 (140) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x7af2000 – 0x7b0bfff com.apple.applepixletvideo 1.2.9 (1.2d9) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x7ba4000 – 0x7bbbfff com.apple.motion.MotionBundle 2.1 /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
    0x7ca4000 – 0x7cddfff com.apple.soundtrackpro.integration 1.0.1 /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0x8905000 – 0x8932fff com.redgiantsoftware.deartifacter ??? (2.1.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Deartifacter.bundle/Contents/MacOS/Deartifacter
    0x895b000 – 0x89cafff com.redgiantsoftware.looksuite ??? (2.1.1) /Library/Application Support/Final Cut Pro System Support/Plugins/LookSuite.bundle/Contents/MacOS/LookSuite
    0x8d6e000 – 0x8d79fff com.apple.QuartzComposer.FxPlugWrapper 1.0 /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0x9929000 – 0x9941fff com.redgiantsoftware.MisFire.Basic.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Basic Scratches.bundle/Contents/MacOS/MisFire Basic Scratches
    0xa4fb000 – 0xa519fff com.redgiantsoftware.MisFire.Deep.Scratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Deep Scratches.bundle/Contents/MacOS/MisFire Deep Scratches
    0xb1cf000 – 0xb1e7fff com.redgiantsoftware.MisFire.Displace ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Displacement.bundle/Contents/MacOS/MisFire Displacement
    0xbda1000 – 0xbdbcfff com.redgiantsoftware.MisFire.Dust ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Dust.bundle/Contents/MacOS/MisFire Dust
    0xc993000 – 0xc9aafff com.redgiantsoftware.MisFire.Fading ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Fading.bundle/Contents/MacOS/MisFire Fading
    0xd563000 – 0xd57afff com.redgiantsoftware.MisFire.Flicker ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Flicker.bundle/Contents/MacOS/MisFire Flicker
    0xe133000 – 0xe14afff com.redgiantsoftware.MisFire.Funk ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Funk.bundle/Contents/MacOS/MisFire Funk
    0xf083000 – 0xf09efff com.redgiantsoftware.MisFire.Gate.Weave ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Gate Weave.bundle/Contents/MacOS/MisFire Gate Weave
    0x10000000 – 0x10057fff com.apple.proapps.AudioMixEngine 2.0 (54) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x2009a000 – 0x200b9fff com.redgiantsoftware.MisFire.Grain ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Grain.bundle/Contents/MacOS/MisFire Grain
    0x20c66000 – 0x20c81fff com.redgiantsoftware.MisFire.MicroScratches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire MicroScratches.bundle/Contents/MacOS/MisFire MicroScratches
    0x2182d000 – 0x21844fff com.redgiantsoftware.MisFire.Post.Contrast ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Post Contrast.bundle/Contents/MacOS/MisFire Post Contrast
    0x223dd000 – 0x223f8fff com.redgiantsoftware.MisFire.Splotches ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Splotches.bundle/Contents/MacOS/MisFire Splotches
    0x22fa4000 – 0x22fbbfff com.redgiantsoftware.MisFire.Vignette ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire Vignette.bundle/Contents/MacOS/MisFire Vignette
    0x24519000 – 0x24546fff com.redgiantsoftware.MisFire ??? (1.1.3) /Library/Application Support/Final Cut Pro System Support/Plugins/MisFire.bundle/Contents/MacOS/MisFire
    0x260b7000 – 0x267ecfff com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0x276ac000 – 0x276b8fff com.apple.PluginManager 1.6 (28) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0x276c4000 – 0x276d5fff com.apple.fxplugframework 1.1 /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0x276e8000 – 0x276e9fff com.apple.compressor.stomp 2.3 /Library/Frameworks/Compressor.framework/Compressor
    0x27805000 – 0x27f37fff com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0x28bad000 – 0x28c96fff com.apple.motion.filters 2.1.2 /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0x28e05000 – 0x29535fff com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0x29f72000 – 0x2a6a8fff com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0x2b41d000 – 0x2b41efff com.apple.qmaster.swamp 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0x2b4fa000 – 0x2b4fbfff com.apple.Helium 2.0.5 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0x2b635000 – 0x2b637fff com.aja.kona.videooutputclock 3.2 /Library/QuickTime/KonaVideoOutputClock.component/Contents/MacOS/KonaVideoOutputClock
    0x2ba75000 – 0x2ba80fff com.apple.fcp.TundraOutputUnit 1.3 /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0x2ba8a000 – 0x2ba8ffff com.apple.audio.AppleHDAHALPlugIn 1.2.4 (1.2.4a21) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x2ba93000 – 0x2ba98fff com.apple.DesktopVideoOut 1.2.4 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0x2bca3000 – 0x2bcadfff com.apple.DVCPROHDVideoOutput 1.2 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0x2bcbb000 – 0x2bce5fff com.apple.audio.SoundManager.Components 3.9.2 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x2bcea000 – 0x2bcf3fff com.apple.IOFWDVComponents 1.9.0 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0x2be05000 – 0x2be57fff com.apple.DVCPROHDAudio 1.2 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0x2beb5000 – 0x2bef1fff com.apple.QuickTimeFireWireDV.component 7.1.3 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0x2c005000 – 0x2c04cfff com.apple.DVCPROHDMuxer 1.2 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0x2c07f000 – 0x2c0c4fff com.apple.audio.CoreAudio.ProMediaIOAVSAVCPlugIn 7.0 /Applications/Final Cut Pro.app/Contents/PlugIns/ProMediaIOAVSAVC.plugin/Contents/MacOS/ProMediaIOAVSAVC
    0x2c15e000 – 0x2c18ffff com.aja.kona.videooutput 3.2 /Library/QuickTime/KonaVideoOutput.component/Contents/MacOS/KonaVideoOutput
    0x2c1af000 – 0x2c203fff com.aja.kona.muxer 3.2 /Library/QuickTime/KonaMuxer.component/Contents/MacOS/KonaMuxer
    0x2c9ae000 – 0x2c9b9fff com.apple.compressor.MediaServerAPI 2.3 /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x2c9c6000 – 0x2c9cefff com.apple.compressor.StompUtil 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x2c9d8000 – 0x2c9defff com.apple.compressor.FilterUI 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0x2c9e6000 – 0x2c9f0fff com.apple.qmaster.SwampUtil 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x3bb09000 – 0x3bb9efff com.apple.AECore 2.3 /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x3bc29000 – 0x3bc52fff com.apple.compressor.ImageProcessing 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x3bc7a000 – 0x3bd20fff com.apple.compressor.StompTypes 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x3bd8d000 – 0x3be62fff com.apple.compressor.transcoding 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x3bf4c000 – 0x3bf7ffff com.apple.compressor.StompUI 2.3 /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x3bf9e000 – 0x3bfc8fff com.apple.qmaster.SwampCore 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x3bff8000 – 0x3c022fff com.apple.qmaster.SwampTypes 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x3c057000 – 0x3c0a0fff com.apple.qmaster.do 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x3c0f5000 – 0x3c0fdfff com.apple.qmaster.SwampService 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x3c10c000 – 0x3c118fff com.apple.qmaster.Status 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x3c131000 – 0x3c138fff com.apple.qmaster.RequestProcessing 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x3c14a000 – 0x3c156fff com.apple.qmaster.ServiceControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x3c16b000 – 0x3c19bfff com.apple.qmaster.ContentControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x3c1cb000 – 0x3c268fff com.apple.qmaster.JobControl 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x3c300000 – 0x3c30cfff com.apple.qmaster.ClusterManager 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x3c31e000 – 0x3c338fff com.apple.qmaster.SwampUI 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x3c350000 – 0x3c35afff com.apple.qmaster.SwampExecutor 2.3 /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x421c1000 – 0x421e9fff com.aja.kona.videooutputcodec 3.2 /Library/QuickTime/KonaVideoOutputCodec.component/Contents/MacOS/KonaVideoOutputCodec
    0x43477000 – 0x4348cfff ThirdPartyPlugins /Users/SPS/Library/Frameworks/ThirdPartyPlugins.framework/Versions/A/ThirdPartyPlugins
    0x43605000 – 0x4367cfff ProCore /Users/SPS/Library/Frameworks/ProCore.framework/Versions/A/ProCore
    0x436a5000 – 0x43703fff ProMedia /Users/SPS/Library/Frameworks/ProMedia.framework/Versions/A/ProMedia
    0x439be000 – 0x44182fff com.apple.ozone.framework 2.1 /Applications/Motion.app/Contents/Frameworks/Ozone.framework/Ozone
    0x4467c000 – 0x446a5fff ProGraphics /Users/SPS/Library/Frameworks/ProGraphics.framework/Versions/A/ProGraphics
    0x4625a000 – 0x4625ffff com.apple.fxmetaplug.ImageUnit 1.1 /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0x46265000 – 0x46267fff com.apple.Helium.HCache 2.0.5 /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0x70000000 – 0x700f9fff com.apple.audio.units.Components 1.4.3 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8fe00000 – 0x8fe49fff dyld 46.9 /usr/lib/dyld
    0x90000000 – 0x9016ffff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x901bf000 – 0x901c1fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x901c3000 – 0x90200fff com.apple.CoreText 1.1.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90227000 – 0x902fcfff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x9031c000 – 0x90770fff com.apple.CoreGraphics 1.258.38 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x90807000 – 0x908cffff com.apple.CoreFoundation 6.4.6 (368.27) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x9090d000 – 0x9090dfff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x9090f000 – 0x90a02fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x90a52000 – 0x90ad1fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90afa000 – 0x90b5efff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x90bcd000 – 0x90bd4fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x90bd9000 – 0x90c4cfff com.apple.framework.IOKit 1.4.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90c61000 – 0x90c73fff libauto.dylib /usr/lib/libauto.dylib
    0x90c79000 – 0x90f1ffff com.apple.CoreServices.CarbonCore 682.15 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90f62000 – 0x90fcafff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x91003000 – 0x91041fff com.apple.CFNetwork 129.18 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x91054000 – 0x91064fff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x9106f000 – 0x910eefff com.apple.SearchKit 1.0.5 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x91128000 – 0x91146fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x91152000 – 0x91160fff libz.1.dylib /usr/lib/libz.1.dylib
    0x91163000 – 0x91302fff com.apple.security 4.5.1 (29002) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x91400000 – 0x91408fff com.apple.DiskArbitration 2.1.1 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x9140f000 – 0x91435fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91447000 – 0x9144efff libbsm.dylib /usr/lib/libbsm.dylib
    0x91452000 – 0x914c8fff com.apple.audio.CoreAudio 3.0.4 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x91519000 – 0x91519fff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x9151b000 – 0x91547fff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x9155a000 – 0x9162efff com.apple.ColorSync 4.4.8 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x91669000 – 0x916dcfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x9170a000 – 0x917b3fff com.apple.QD 3.10.21 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x917d9000 – 0x91824fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x91843000 – 0x91859fff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91865000 – 0x91880fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x9188b000 – 0x918c8fff com.apple.LaunchServices 181 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x918dc000 – 0x918e8fff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x918ef000 – 0x9192afff com.apple.ImageIO.framework 1.5.0 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9193c000 – 0x919eefff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91a34000 – 0x91a4afff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91a4f000 – 0x91a6dfff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91a72000 – 0x91ad0fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91ae2000 – 0x91ae6fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91ae8000 – 0x91b65fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91b69000 – 0x91ba6fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91bac000 – 0x91bc6fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91bcb000 – 0x91bcdfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91bcf000 – 0x91bcffff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91bd1000 – 0x91c5ffff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91c66000 – 0x91c66fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91c68000 – 0x91cc1fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x91cca000 – 0x91ceefff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x91cf6000 – 0x920fffff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x92139000 – 0x924edfff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x9251a000 – 0x92597fff com.apple.DesktopServices 1.3.4 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x925d8000 – 0x92808fff com.apple.Foundation 6.4.7 (567.28) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92914000 – 0x929f2fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x92a0f000 – 0x92afcfff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92b0c000 – 0x92b23fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92b2e000 – 0x92b86fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92b9a000 – 0x92b9afff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92b9c000 – 0x92bacfff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92bbb000 – 0x92bc3fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x92bc9000 – 0x92bcffff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92bd5000 – 0x92c66fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x92c7a000 – 0x92c7efff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x92c81000 – 0x92c9ffff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x92cb1000 – 0x92cb7fff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x92cbd000 – 0x92d20fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x92d47000 – 0x92d88fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x92daf000 – 0x92dbdfff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x92dc4000 – 0x92dc9fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x92dce000 – 0x930c2fff com.apple.HIToolbox 1.4.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x931c8000 – 0x931d3fff com.apple.opengl 1.4.12 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x931d8000 – 0x931f3fff com.apple.DirectoryService.Framework 3.2 /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x93207000 – 0x93239fff com.apple.MediaKit 8.7 (350.1) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x93243000 – 0x93243fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x93245000 – 0x938fbfff com.apple.AppKit 6.4.8 (824.42) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x93c7c000 – 0x93cf5fff com.apple.CoreData 90 /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x93d2e000 – 0x93de6fff com.apple.audio.toolbox.AudioToolbox 1.4.3 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x93e28000 – 0x93e28fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x93e2a000 – 0x93ffcfff com.apple.QuartzCore 1.4.9 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9404d000 – 0x9408efff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x94096000 – 0x940d0fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x9410c000 – 0x94154fff com.apple.bom 8.5 (86.3) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x9415e000 – 0x9419cfff com.apple.vmutils 4.0.2 (93.1) /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x94259000 – 0x94268fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x9426f000 – 0x9427afff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x942c6000 – 0x942e0fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x942e6000 – 0x9459ffff com.apple.QuickTime 7.1.3 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94701000 – 0x94847fff com.apple.AddressBook.framework 4.0.4 (485.1) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x948d3000 – 0x948e2fff com.apple.DSObjCWrappers.Framework 1.1 /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x948e9000 – 0x94912fff com.apple.LDAPFramework 1.4.2 (69.1.1) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x94918000 – 0x94927fff libsasl2.2.dylib /usr/lib/libsasl2.2.dylib
    0x9492b000 – 0x94950fff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
    0x9495c000 – 0x94979fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
    0x94a1d000 – 0x94a1dfff com.apple.DiscRecording 3.1.4 (???) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x94a1f000 – 0x94a9dfff com.apple.DiscRecordingEngine 3.1.4 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingEngine.framework/Versions/A/DiscRecordingEngine
    0x94acd000 – 0x94b0ffff com.apple.DiscRecordingContent 3.1.4 /System/Library/Frameworks/DiscRecording.framework/Versions/A/Frameworks/DiscRecordingContent.framework/Versions/A/DiscRecordingContent
    0x94c79000 – 0x94c9dfff libcurl.3.dylib /usr/lib/libcurl.3.dylib
    0x95465000 – 0x954a1fff com.apple.QTKit 7.1.3 /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x954f1000 – 0x95529fff com.apple.PDFKit 1.0.2 /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x95874000 – 0x95946fff com.apple.prokit 3.1.1 (591) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0x96052000 – 0x96088fff com.apple.audio.midi.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x96451000 – 0x96451fff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x969cb000 – 0x96a99fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x96ab4000 – 0x96ab5fff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib
    0x96ab7000 – 0x96abcfff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x96b9f000 – 0x96bb8fff com.apple.AppleVAFramework 3.3.1 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x9748a000 – 0x97560fff com.apple.QuartzComposer 1.2.3 (32.21) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x975e9000 – 0x975e9fff com.apple.quartzframework 1.0 /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x97966000 – 0x97a6cfff com.apple.DiskImagesFramework 10.4.7 (114.2) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x97ada000 – 0x97ae7fff libbz2.1.0.dylib /usr/lib/libbz2.1.0.dylib
    0x97dac000 – 0x98896fff com.apple.QuickTimeComponents.component 7.1.3 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x98aa5000 – 0x98aa7fff com.apple.QuickTimeH264.component 7.1.3 /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x98aa9000 – 0x98c51fff QuickTimeH264.scalar /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0x98cc1000 – 0x98d7efff com.apple.QuickTimeMPEG4.component 7.1.3 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x99601000 – 0x99601fff com.apple.iokit.dvcomponentglue 1.9.0 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9960e000 – 0x99654fff com.apple.viceroy.codec 32.1 /System/Library/Components/VCH263Codec.component/VCH263Codec
    0x9ac3e000 – 0x9ac3efff libmx.A.dylib /usr/lib/libmx.A.dylib
    0x9fffc000 – 0x9fffefff Motion /Library/Frameworks/Motion.framework/Versions/A/Motion
    Model: MacPro1,1, BootROM MP11.005C.B04, 4 processors, Dual-Core Intel Xeon, 3 GHz, 4 GB
    Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
    Memory Module: DIMM Riser A/DIMM 1, 512 MB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser A/DIMM 2, 512 MB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 1, 512 MB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 2, 512 MB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser A/DIMM 3, 1 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser A/DIMM 4, 1 GB, DDR2 FB-DIMM, 667 MHz
    Network Service: Built-in Ethernet 1, Ethernet, en0
    PCI Card: pci-bridge, sppci_pci2pcibridge, Slot-4
    PCI Card: pci-bridge, sppci_pci2pcibridge, Slot-3
    PCI Card: ATY,RadeonX1900, Display, Slot-1
    Serial ATA Device: WDC WD2500JS-41SGB0, 232.89 GB
    Parallel ATA Device: PIONEER DVD-RW DVR-111D
    Fibre Channel Device: SCSI Target Device @ 0
    USB Device: Hub, Up to 480 Mb/sec, 500 mA
    USB Device: USB Receiver, Logitech, Up to 1.5 Mb/sec, 500 mA
    USB Device: Flash Card Reader, Generic, Up to 480 Mb/sec, 500 mA
    USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
    USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
    FireWire Device: built-in_hub, unknown_value, Unknown
    FireWire Device: LaCie Big Disk Extreme LUN 0, LaCie Group SA, Up to 800 Mb/sec
    FireWire Device: Io, AJA Video Systems, Inc., Up to 400 Mb/sec
    Jas L. replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
