Activity Forums Audio fcp crashes in audio import
  • fcp crashes in audio import
    Posted by Nikos Papadopoulos on September 30, 2012 at 4:04 pm
    I have imported an 1.5 GB aiff audio file and fcp crashes all the time.
    I had no problems before adding this file. Now I don’t know what to do. Have tried everything, trashed preferences, re install fcp.
    All timelines without this audio file work without crashing the program. What should I do?
    Nikos Papadopoulos replied 13 years, 7 months ago 2 Members · 2 Replies
  • Andrew Rendell
    September 30, 2012 at 7:33 pm
    The first thing I’d do would be to check the audio settings – is it 48kHz 16bit? FCP will handle other settings but not happily, so convert it if it’s different.
    2nd thing would be to break it into sections using the audio editor of your choice, then import them and see whether a series of smaller files work ok.
  • Nikos Papadopoulos
    October 5, 2012 at 11:29 am
    thanks for the reply.
    apparently fcp crashes with or without the new audio.
