Activity › Forums › Apple Final Cut Pro Legacy › FCP crashes at Capture and Log
  • FCP crashes at Capture and Log
    Posted by Filip Szymanski on November 5, 2008 at 12:19 am
    Hey guys,
    I’m new to Macs (got my first one this morning) as well as Final Cut Pro. I have some footage I’m trying to import from a Canon HDV20 using Final Cut Pro 5. Every time I hit capture and log, FCP crashes. FCP is set to import HDV/60i same as the camera. Is there some support drivers for the canon I need to download for FCP? Or is there some other solution?
    Chris Borjis replied 17 years, 10 months ago 2 Members · 1 Reply
  • Chris Borjis
    November 5, 2008 at 12:33 am
    try the “1080i firewire basic” easy setup
    check and make sure the canon is manually
    set for HDV output (it has a tendency to go back to DV)
    I don’t think fcp 5.x supports the 24f mode
    if that’s what’s on tape.
    trash preferences if it still won’t go.
