Activity Forums Apple Final Cut Pro Legacy FCP crashes and error code -600 What the…*#
  • FCP crashes and error code -600 What the…*#
    Posted by Monica F.p.williams on May 18, 2006 at 10:33 pm
    Hi everyone, I am working on a doc whith a huge amount of material (100 hours)(!)
    my system crashes 3/4 times a day and even if I save frequently, every time I lose some of the work done (VERY frustrating) I am not doing effects or complicated thing, I am at most using two video tracks for sync two cameras. After FCP crashes when I try to reopen it, I get this message:
    An unexpected error occurred (error code -600)
    I went and look on apple support but no luck….
    any Ideas? PLEEEEEASE.
    By the way this G5 have only one processor.
    Specs:
    Machine Name: Power Mac G5
    Machine Model: PowerMac7,2
    CPU Type: PowerPC 970 (2.2)
    Number Of CPUs: 1
    CPU Speed: 1.6 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4 GB
    Bus Speed: 800 MHz
    Boot ROM Version: 5.1.5f2
    Monica F.P.williams
    crocodile editing
    Dixon Johnston replied 16 years, 2 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    May 18, 2006 at 10:42 pm
    What else do you have hooked up to your computer and do you have a capture card?
    Jeremy
  • Monica F.p.williams
    May 18, 2006 at 11:10 pm
    Hi Geremy
    No, I don’t have a capture card and the only thing hooked up is an external firewire Gdrive.
    Monica
    Monica F.P.williams
    crocodile editing
  • Jeremy Garchow
    May 18, 2006 at 11:36 pm
    How full is your drive? how are you monitoring your footage?
    May 18, 2006 at 11:40 pm
    Hi again,
    I have plenty space in all my drives,sorry but I don’t understand the monitoring question.
    ciao
    Monica
    Monica F.P.williams
    crocodile editing
  • Jeremy Garchow
    May 18, 2006 at 11:47 pm
    HOw may drivers do you have hooked up? SOrry for the back and forth, just being thorough. Are you not watching your footage on a tv?
    May 19, 2006 at 12:12 am
    Don’t worry thank you for help !!! I don’t have tv monitor I have a laCie and a viewsonic computer monitor
    the OS is in a sata drive and still have 236 GB avaliable
    the other internal hd
    Capacity: 465.65 GB
    Available: 73.97 GB
    Writable: Yes
    File System: HFS+
    BSD Name: disk2s3
    FireWire external
    800 Mb/sec
    OXFORD IDE Device 1:
    G-Tech G-RAID
    Maximum Speed: Up to 800 Mb/sec
    Connection Speed: Up to 800 Mb/sec
    Sub-units:
    OXFORD IDE Device 1 Unit:
    Unit Software Version: 0x10483
    Firmware Revision: 0x102
    Product Revision Level: V36O
    Sub-units:
    OXFORD IDE Device 1 SBP-LUN:
    Capacity: 465.77 GB
    Removable Media: Yes
    BSD Name: disk2
    OS9 Drivers: No
    S.M.A.R.T. status: Not Supported
    Would this help?
    Monica F.P.williams
    crocodile editing
  • Ron James
    May 19, 2006 at 3:51 am
    I’m guessing it’s time to split up your project file. I’ve just finished up a doc that probably had the same if not more hours onboard. Could’ve been a nightmare. But, thankfully, I know one of FCP’s weaknesses is its database.
    Do you still have all your stuff, from the very beginning, in one project file?
    If so, take out only your main sequence and start a new project. I start this from the very beginning, keeping a separate file for just Log & Capture. Then, I take selects into a new project file to start cutting. Then, when I’ve got multiple cuts, I take the current seq’s into a new project. The thing is, you can really mess things up when you’re trying to open multiple huge seq’s, plus tons of clips and media all in one project. But, FCP does fine when they’re open side by side in separate projects.
    HTH!
    G5 Dual 2.7 GHz
    2 GB RAM
    OS 10.4.6
    FCP 5.0.4
    QT 7.0.4
  • Ron James
    May 19, 2006 at 3:57 am
    BTW (if you’ve read my post below)…
    If you’re having trouble even opening FCP, try unplugging your FW drive before booting up your Mac and launch your project. That way, all your media files should be offline. That way, you should at least be able to save a backup of your current project file.
    G5 Dual 2.7 GHz
    2 GB RAM
    OS 10.4.6
    FCP 5.0.4
    QT 7.0.4
    May 19, 2006 at 5:21 pm
    Hi! thank you for the good suggestions.
    I totally agree on your take on the huge database, I’ll try that.
    I am the last of several people tha worked in this doc and for several reasons (lack of experience in managing FCP etc etc) I have the files all over the place ,backups ,QT of entire timelines from 3 years ago, together with other files that should’t be in the media drives,
    I just checked there are 5 different capture scratch folders. I think that this also could be the issue.
    hard for FCP to have to go look for files all over.
    So what if I consolidate all media files with media manager in one drive that will contain only 1 capture scratch that belong to the project?
    I hope that this make sense(sometimes my english is not really correct)
    ciao
    Monica
    Monica F.P.williams
    crocodile editing
  • Ron James
    May 19, 2006 at 11:08 pm
    Monica…
    Yes, this is something you definitely learn from experience after using the program for a huge project.
    You could consolidate to a clean drive, definitely, or you could start a new project and just move what you need into it and work with the existing media. I think, based on my own experience, it’s most important at this stage to reduce the load inside the project itelf (number of sequences, clips, subclips, etc) and see if that helps. Try taking only your main sequence into a fresh new project and see if that helps.
    Have you lost any data? Or is your project file opening okay?
    Consolidating will streamline your project and create a new project for you, too, so I don’t think you can go wrong with that. What I’d do, though, to be safe, is make Media Manager *copy* with the ‘delete unused media’ checked and target a new drive for the media. That way, you will consolidate, but still have your original media intact as a backup (until you can ensure everything is okay and then you could just get rid of it, if that’s what you want to do).
    Hope that helps!
    Ron
    G5 Dual 2.7 GHz
    2 GB RAM
    OS 10.4.6
    FCP 5.0.4
    QT 7.0.4
