Activity Forums Apple Final Cut Pro Legacy FCP crashes after applying filter
  • FCP crashes after applying filter
    Posted by Neil Gregory on February 11, 2008 at 5:14 pm
    Hi Everyone,
    FCP crashes out when using the magic bullet filter ‘MisFire Post Contrast’.
    I have trashed prefs, safe booted, repaired permissions and all the usual stuff.
    I am on the latest version and my software is all up to date.
    Any ideas??
    Neil
    Andreas Karoliussen replied 18 years, 7 months ago 2 Members · 1 Reply
  • Andreas Karoliussen
    February 11, 2008 at 9:02 pm
    What material are you applying the filter to?
    Does it happen to other clips?
    Is it somthing extra with this clip? (fx plugg filters, reverse, speed changes etc)
    Media file could be corrupt or you are using a codec like “Photo Jpeg” or “DV”
    If so, try to redigitize/export to – uncompressed 10bit 4.2.2
    Nice if you give some more info in your first post
    Good luck,
    Andreas
