Activity Forums Apple Final Cut Pro Legacy FCP crashed, now MXO won’t work
  • FCP crashed, now MXO won’t work
    Posted by Hunter Stevens on June 22, 2008 at 7:11 am
    I was working away in FCP 6 on an 8-core mac with Matrox MXO, when the FCP just crashed, completely closed on me back to the desktop. When I reboot, MXO no longer works. Settings are still all correct for the MXO, I’m working DVC Pro HD 720/24, but it just doesn’t output video or audio. The MXO system preferences monitors temp fine and flickers screen when switching the genlock, just appears that FCP won’t recognize it. I have restarted the mac, the mxo and no luck.
    Any ideas would be greatly appreciated, the thought of spending my Sunday reinstalling FCP for 4 hours or whatever ridiculous time it took when 1st set up is not fun.
    Thanks in advance.
    David Smith replied 18 years, 3 months ago 5 Members · 6 Replies
  • Walter Biscardi
    June 22, 2008 at 1:09 pm
    Try the usual:
    Repair Disk Permissions
    Trash FCP Preferences
    Trash MXO Preferences if there are any
    Run Disk Warrior if none of that works.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Gary Adcock
    June 22, 2008 at 2:56 pm
    [walter biscardi] “Try the usual: “
    Reinstall the drivers.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Shane Ross
    June 22, 2008 at 5:25 pm
    [gary adcock] “Reinstall the drivers.”
    I was going to say that. But I am still recovering from HEAT EXHAUSTION from the two days I worked in the 106 degree heat. Gary, how did you manage? The AJA booth had it worse than we did.
    Shane
  • Hunter Stevens
    June 23, 2008 at 7:19 am
    I tried everything on the list, nothing worked until reinstalled FCP. A little scary that I can just be dumped out of FCP for an unknown error and have to reinstall. Thanks for your responses.
    Never let the odds keep u from doing what u know in ur heart u were meant to do.
  • Gary Adcock
    June 23, 2008 at 1:19 pm
    [Shane Ross] “was going to say that. But I am still recovering from HEAT EXHAUSTION from the two days I worked in the 106 degree heat. Gary, how did you manage? The AJA booth had it worse than we did. “
    Dude….
    its called GLASS BLOWING (my hobby), I am used to working for 8 hrs in 120-150+ temps. I stand 54″ from a 3000 degree opening when reheating the work.
    Now the Sun was a different issue- that was what got to me – it was so, so, so bright and all of the UV rays bouncing around my prescription sunglasses(rated 800+ for UV) Days like those really need wrap around lenses that mine did not have.
    Good to see you as always too.
    gary adcock
    Studio37
  • David Smith
    June 23, 2008 at 11:16 pm
    I find my MXO – Powerbook – OS 10.4.11 and FCP 5 combination can get a bit finicky when things change. I usually have to restart after changing the codec I’m viewing, for example. I wasn’t clear from reading your post if you checked the View Menu settings after your crash and restart. External Video often resets to off on my set up, and Refreshing video devices sometimes helps me out too.
    Regards,
    David
