  • Posted by John Watts on April 1, 2009 at 6:46 pm
    Hi Folks,
    My FCP system has crashed several times over the past few days. What happens is, I open FCP click in the timeline, then I get the beachball then crash. When this happens I restart my G5, repai disk permissions, use FCP rescue, then reopen the project. Below are the details in the error report sent to apple
    Btw my system is: G5 PPC, FCP version 6
    Model: PowerMac7,3, BootROM 5.1.8f7, 2 processors, PowerPC G5 (2.2), 2 GHz, 3 GB
    Graphics: GeForce FX 5200, GeForce FX 5200, spdisplays_agp_device, 64 MB
    Memory Module: DIMM0/J11, 256 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM1/J12, 256 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM2/J13, 256 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM3/J14, 256 MB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM4/J41, 1 GB, DDR SDRAM, PC3200U-30330
    Memory Module: DIMM5/J42, 1 GB, DDR SDRAM, PC3200U-30330
    Modem: Jump, V.92, Version 1.0
    Network Service: Ethernet, Ethernet, en0
    PCI Card: firewire, ieee1394, SLOT-2
    PCI Card: pci10b5,a100, sppci_video, SLOT-4
    Serial ATA Device: ST3160023AS, 149.05 GB
    Parallel ATA Device: PIONEER DVD-RW DVR-115D
    USB Device: Keyboard Hub, (null) mA
    USB Device: Apple Optical USB Mouse, (null) mA
    USB Device: Apple Keyboard, (null) mA
    USB Device: H4, (null) mA
    FireWire Device: HDD, Iomega, 800mbit_speed
    FireWire Device: HDR-FX1, Sony, 400mbit_speed
    Process: Final Cut Pro [904]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.5 (6.0.5)
    Build Info: FCPApp-810171515~36
    Code Type: PPC (Native)
    Parent Process: launchd [114]
    Date/Time: 2009-04-01 17:23:32.420 +0100
    OS Version: Mac OS X 10.5.6 (9G55)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x000000002aaff00e
    Crashed Thread: 19
    Thread 0:
    0 com.apple.QuickTime 0x9422a400 DoBandedDecompress + 11024
    1 com.apple.QuickTime 0x9422fdb8 ICMDeviceLoop + 3560
    2 com.apple.QuickTime 0x94208f3c DecompressSequenceFrameWhen + 860
    3 com.apple.QuickTime 0x9423c55c ICMDecompressionSessionDecodeFrame + 1244
    4 com.apple.FinalCutPro 0x00443ea4 Source::DecompressFrame(long long, unsigned long, KGQTCanvasFormat, RTBufferSize, long, RTBufferPool*, KGDictInt*) + 3876
    5 com.apple.FinalCutPro 0x0047fc10 SetupSrcCanvasN(XXGlobals*, EffectTree*, long, long, Output*, bool*) + 1776
    6 com.apple.FinalCutPro 0x00480ce4 DecodeEffectFrameN(XXGlobals*, EffectTree*, long, unsigned char, Output*, bool*) + 264
    7 com.apple.FinalCutPro 0x00481b88 DecodePipeTree(XXGlobals*, Output*) + 552
    8 com.apple.FinalCutPro 0x0044d664 FCPMediaHandler::RenderFrames(long long, bool) + 3688
    9 com.apple.FinalCutPro 0x0044dcbc FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 608
    10 com.apple.FinalCutPro 0x0044eb8c FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 12
    11 com.apple.FinalCutPro 0x00447408 FCPMHDispatch(ComponentParameters*, char**) + 56
    12 …ickTimeComponents.component 0x969bf940 MediaIdle + 48
    13 …ickTimeComponents.component 0x9640e3a4 doGenericIdle + 2244
    14 …ickTimeComponents.component 0x96410e74 GenericMoviesTask + 900
    15 com.apple.FinalCutPro 0x00447428 FCPMHDispatch(ComponentParameters*, char**) + 88
    16 com.apple.QuickTime 0x94446190 MediaMoviesTask + 48
    17 com.apple.QuickTime 0x9427e400 TaskMovie_priv + 3824
    18 com.apple.QuickTime 0x9426b244 frequentlyTaskMovies + 244
    19 com.apple.CoreFoundation 0x92f339d8 CFRunLoopRunSpecific + 2968
    20 com.apple.HIToolbox 0x90f7bbc4 RunCurrentEventLoopInMode + 264
    21 com.apple.HIToolbox 0x90f7b9e8 ReceiveNextEventCommon + 412
    22 com.apple.HIToolbox 0x90fd9a14 RunApplicationEventLoop + 148
    23 com.apple.FinalCutPro 0x0016ad00 KGMainEvent(void*) + 48
    24 com.apple.FinalCutPro 0x002e84ac main + 60
    25 com.apple.FinalCutPro 0x00002ed8 _start + 756
    26 com.apple.FinalCutPro 0x00002bdc start + 44
    Thread 1:
    0 libSystem.B.dylib 0x925f8d20 select$DARWIN_EXTSN + 12
    1 com.apple.CoreFoundation 0x92f3e9c8 __CFSocketManager + 764
    Thread 2:
    0 libSystem.B.dylib 0x9259bb6c __semwait_signal + 12
    1 libSystem.B.dylib 0x925d83cc _pthread_cond_wait + 1580
    2 libGLProgrammability.dylib 0x959d7bc8 glvmDoWork + 120
    3 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 3:
    0 libSystem.B.dylib 0x925952d8 mach_wait_until + 8
    1 libSystem.B.dylib 0x9262068c nanosleep + 324
    2 libSystem.B.dylib 0x92620534 usleep + 68
    3 com.apple.FinalCutPro 0x00449c44 DisplayQueue::Run() + 948
    4 com.apple.FinalCutPro 0x004896b0 Thread::RunHelper(void*) + 28
    5 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 4:
    0 libSystem.B.dylib 0x925951b8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x925d82d8 _pthread_cond_wait + 1336
    2 com.apple.FinalCutPro 0x0045f334 Synchronizable::Wait() + 44
    3 com.apple.FinalCutPro 0x005031bc WorkUnitPerformer::Run() + 68
    Thread 5:
    0 libSystem.B.dylib 0x92595158 mach_msg_trap + 8
    1 libSystem.B.dylib 0x9259c07c mach_msg + 56
    2 com.apple.CoreFoundation 0x92f33554 CFRunLoopRunSpecific + 1812
    3 com.apple.CoreFoundation 0x92f33ddc CFRunLoopRun + 60
    4 com.apple.DVCPROHDMuxer 0x0fa35e3c AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 428
    Thread 6:
    3 com.apple.audio.CoreAudio 0x92108f84 HALRunLoop::OwnThread(void*) + 212
    4 com.apple.audio.CoreAudio 0x92108dc0 CAPThread::Entry(CAPThread*) + 104
    Thread 7:
    3 ….CoreMediaIOServicesPrivate 0x91498e6c MIO::DAL::RunLoop::OwnThread(void*) + 212
    4 ….CoreMediaIOServicesPrivate 0x9149b450 CAPThread::Entry(CAPThread*) + 104
    Thread 8:
    0 libSystem.B.dylib 0x925951d8 semaphore_timedwait_signal_trap + 8
    1 libSystem.B.dylib 0x925d82c8 _pthread_cond_wait + 1320
    2 …ple.CoreServices.CarbonCore 0x93a51b08 TSWaitOnConditionTimedRelative + 240
    3 …ple.CoreServices.CarbonCore 0x93a518dc TSWaitOnSemaphoreCommon + 428
    4 …ple.CoreServices.CarbonCore 0x93a83950 TimerThread + 68
    Thread 9:
    4 …ickTimeComponents.component 0x963a7de0 ReadSchedulerThreadEntryPoint + 5312
    Thread 10:
    2 com.apple.audio.CoreAudio 0x9211a9cc HP_IOThread::WorkLoop() + 488
    3 com.apple.audio.CoreAudio 0x9211a7cc HP_IOThread::ThreadEntry(HP_IOThread*) + 12
    Thread 11:
    4 com.apple.DesktopServices 0x94d67568 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 104
    5 …ple.CoreServices.CarbonCore 0x93a71478 PrivateMPEntryPoint + 76
    6 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 12:
    4 com.apple.DesktopServices 0x94d676e4 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 176
    Thread 13:
    2 …ple.CoreServices.CarbonCore 0x93a73688 TSWaitOnCondition + 132
    3 …ple.CoreServices.CarbonCore 0x93a51ae4 TSWaitOnConditionTimedRelative + 204
    4 …ple.CoreServices.CarbonCore 0x93a73244 MPWaitOnQueue + 272
    5 com.apple.DesktopServices 0x94d72c24 TNodeSyncTask::SyncTaskProc(void*) + 88
    6 …ple.CoreServices.CarbonCore 0x93a71478 PrivateMPEntryPoint + 76
    7 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 14:
    0 libSystem.B.dylib 0x925d6864 kevent + 12
    1 com.apple.CoreFoundation 0x92f0ad40 __monitor_file_descriptor__ + 88
    Thread 15:
    2 com.apple.Foundation 0x90264b24 -[NSCondition waitUntilDate:] + 384
    3 com.apple.Foundation 0x90264950 -[NSConditionLock lockWhenCondition:beforeDate:] + 268
    4 com.apple.AppKit 0x915a3eac -[NSUIHeartBeat _heartBeatThread:] + 664
    5 com.apple.Foundation 0x90227764 __NSThread__main__ + 1004
    Thread 16:
    4 …ple.CoreServices.CarbonCore 0x93a7acc8 AIOFileThread(void*) + 1068
    Thread 17:
    3 …ple.CoreServices.CarbonCore 0x93a73244 MPWaitOnQueue + 272
    4 com.apple.DesktopServices 0x94d748e4 TFolderSizeTask::FolderSizeTaskProc(void*) + 88
    Thread 18:
    4 com.apple.IOFWDVComponents 0x0fbda8cc DVSignalSync + 192
    Thread 19 Crashed:
    0 ….audio.toolbox.AudioToolbox 0x9454ed20 TInterleaver::Interleave(int, void**, void*, int) + 276
    1 ….audio.toolbox.AudioToolbox 0x945375c8 CBRConverter::RenderOutput(CABufferList*, unsigned long, unsigned long&, AudioStreamPacketDescription*) + 212
    2 ….audio.toolbox.AudioToolbox 0x94537300 BufferedAudioConverter::FillBuffer(unsigned long&, AudioBufferList&, AudioStreamPacketDescription*) + 332
    3 ….audio.toolbox.AudioToolbox 0x94537470 AudioConverterChain::RenderOutput(CABufferList*, unsigned long, unsigned long&, AudioStreamPacketDescription*) + 140
    4 ….audio.toolbox.AudioToolbox 0x94537300 BufferedAudioConverter::FillBuffer(unsigned long&, AudioBufferList&, AudioStreamPacketDescription*) + 332
    5 ….audio.toolbox.AudioToolbox 0x9454cd54 AudioConverterFillComplexBuffer + 292
    6 com.apple.fcp.DVOutputUnit 0x0bb9d8e4 AUDVOutputUnit::PullSamples(short*, unsigned long, unsigned long) + 164
    7 com.apple.fcp.DVOutputUnit 0x0bb9d9a4 AUDVOutputUnit::FillFrameFromStream(void*, unsigned long, unsigned short&) + 124
    8 com.apple.fcp.DVOutputUnit 0x0bb9ef08 AUDVOutputUnit::FillFrame(void**, unsigned long) + 324
    9 com.apple.fcp.DVOutputUnit 0x0bb9f214 IDHOverride::HandleWrite(IDHParameterBlock*) + 132
    10 com.apple.fcp.DVOutputUnit 0x0bb9f450 IDHOverride::ComponentDispatch(ComponentParameters*, char**) + 196
    11 com.apple.FinalCutPro 0x004d3230 IDHDispatch(ComponentParameters*, char**) + 676
    12 …ickTimeFireWireDV.component 0x0c0be454 IDHWrite + 36
    13 …ickTimeFireWireDV.component 0x0c0b191c FWMuxerIdle + 1212
    14 …ickTimeFireWireDV.component 0x0c0b19dc IsochWriteCallback + 60
    15 com.apple.IOFWDVComponents 0x0fbd8500 checkSeed + 6400
    16 com.apple.IOFWDVComponents 0x0fbd9b08 processOpen + 3580
    17 com.apple.IOFWDVComponents 0x0fbde024 DVDeviceTerminate + 2120
    18 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 20:
    0 libSystem.B.dylib 0x925951c8 semaphore_timedwait_trap + 8
    1 …ple.CoreServices.CarbonCore 0x93a85884 MPWaitOnSemaphore + 104
    2 …ickTimeComponents.component 0x966ebdf0 DecompressFramesMPTask + 96
    3 …ple.CoreServices.CarbonCore 0x93a71478 PrivateMPEntryPoint + 76
    4 libSystem.B.dylib 0x925d7024 _pthread_start + 316
    Thread 21:
    Thread 22:
    4 …ple.CoreServices.CarbonCore 0x93a83ee0 DeferredTaskThread + 68
    Thread 19 crashed with PPC Thread State 32:
    srr0: 0x9454ed20 srr1: 0x0200f030 dar: 0x2aaff00e dsisr: 0x42000000
    r0: 0x0000ffa3 r1: 0xf072b6d0 r2: 0xffffffa3 r3: 0x01f9552a
    r4: 0x01f9552a r5: 0x01f9552a r6: 0x00000000 r7: 0x00000000
    r8: 0x00000000 r9: 0x00000000 r10: 0x00000000 r11: 0x00000000
    r12: 0x2aaff00c r13: 0x43300000 r14: 0x0fbe0260 r15: 0x00000000
    r16: 0x00000000 r17: 0xffffffff r18: 0x00000077 r19: 0x000000ef
    r20: 0x2aafdd6c r21: 0x2c06d4d0 r22: 0x000001df r23: 0x00000000
    r24: 0x00000010 r25: 0x00000020 r26: 0x2dc6552a r27: 0x2dc658fa
    r28: 0x01f9552a r29: 0x01f9552a r30: 0x01f9552a r31: 0x9454ec18
    cr: 0x44002244 xer: 0x00000000 lr: 0x945375cc ctr: 0x0000014b
    vrsave: 0x00000000
    Binary Images:
    0x1000 – 0x787fdf com.apple.FinalCutPro 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    0xb57000 – 0xb5cfe7 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
    0xb62000 – 0xb63fff com.apple.iokit.dvcomponentglue 1.9.5 (1.9.5) <143d5a0b230245035fb6364b29f6b76b> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0xb67000 – 0xb77fdf com.apple.AERegistration 1.2 (72) /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0xb89000 – 0xb91fd7 com.apple.AEProfiling 1.2 (18) /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0xb99000 – 0xd12fff com.apple.prokit 4.5 (722) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0xde8000 – 0xe1bfcb com.apple.AVCVideoServices 1.0 (38) /Applications/Final Cut Pro.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
    0xe3c000 – 0xeb0fdf com.apple.ProFX 1.2.3 (1.2.3) /Library/Frameworks/ProFX.framework/Versions/A/ProFX
    0xedb000 – 0xfddffd com.apple.DiskImagesFramework 10.5.4 (195.2.2) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x1040000 – 0x1097027 com.apple.proapps.MIO 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
    0x10d3000 – 0x10dffc3 com.apple.finalcutstudio.prometadatasupport 0.5 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x10e9000 – 0x110aff1 libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
    0x1112000 – 0x1145ffb com.apple.MediaKit 9.1 (401) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x1155000 – 0x1223ff5 com.apple.DiscRecording 4.0.3 (4030.4.3) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x128a000 – 0x12b7ffb libcurl.4.dylib ??? (???) /usr/lib/libcurl.4.dylib
    0x12c1000 – 0x12f6fff FWAVCPrivate ??? (???) /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
    0x132d000 – 0x1371fff com.apple.vmutils 4.1 (104) <16b044379a7172567dae7a54ded38ffb> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
    0x1742000 – 0x1746fe7 +Motion ??? (???) <7720a0266bcb470f928cc2e387df8684> /Library/Frameworks/Motion.framework/Versions/A/Motion
    0x1751000 – 0x1754ff3 com.apple.QuickTimeH264.component 7.5.5 (995.22.12) /Library/Application Support/ProApps/MIO/RAD/Components/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x1759000 – 0x1760ff7 com.apple.proapps.mrcheckpro 1.4 (204) /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x17e6000 – 0x17ebfd3 com.apple.LiveType.component 2.1.3 (2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x3add000 – 0x3b42fd7 com.apple.LiveType.framework 2.1.3 (2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
    0x3b64000 – 0x3bccfff +com.DivXInc.DivXDecoder 6.4.0 (6.4.0) /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0x3bd9000 – 0x3c21feb com.apple.motion.component 1.0 (1.0) <4473fc9ee73f45bab158c4b9cdcb37e4> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x3c27000 – 0x3d4bff9 +QuickTimeH264.altivec ??? (???) <3e4b7531a41277f28c558d3050d64b89> /Library/Application Support/ProApps/MIO/RAD/Components/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x3da2000 – 0x3dbefff GLRendererFloat ??? (???) <3e5d8f34d61deb0515b3162ab86eec5e> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x882e000 – 0x89e0ff7 com.apple.RawCamera.bundle 2.0.10 (2.0.10) <385afe576f8fd60530711a5eab4ed182> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x9532000 – 0x96a9ffb GLEngine ??? (???) <842f38857bb67e7ddebce958369dbb55> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x96db000 – 0x9864ff6 com.apple.GeForceFXGLDriverPPC 1.5.36 (5.3.6) <945a8f3837c174ada803282cc6234a08> /System/Library/Extensions/GeForceFXGLDriverPPC.bundle/Contents/MacOS/GeForceFXGLDriverPPC
    0xacd7000 – 0xad04fd3 com.apple.FinalCutPro.Plugins.AfterEffects 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
    0xad0d000 – 0xad11fd3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
    0xad15000 – 0xad2efef com.apple.FinalCutPro.Plugins.AudioMixer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
    0xad3c000 – 0xad58ffb com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0xad6e000 – 0xad8ffff libexpat.1.dylib ??? (???) /usr/lib/libexpat.1.dylib
    0xad96000 – 0xae46fe7 com.apple.FinalCutPro.Plugins.Browser 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
    0xae61000 – 0xae67fdb com.apple.FinalCutPro.Plugins.Cache Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
    0xae6b000 – 0xae81fd3 com.apple.FinalCutPro.CinemaTools 4.0.1 (4.0.1) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
    0xae8c000 – 0xae97fc1 com.apple.FinalCutPro.Plugins.CTHelper 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
    0xae9e000 – 0xaec4fc3 com.apple.FinalCutPro.Plugins.EditTape 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
    0xaed3000 – 0xaf1dff8 com.apple.FinalCutPro.Plugins.EDL Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
    0xaf32000 – 0xaf3aff3 com.apple.FinalCutPro.Plugins.Effect Builder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
    0xaf3e000 – 0xaf4bfff com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
    0xaf52000 – 0xaf85fda com.apple.FinalCutPro.Plugins.FCS Engine 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
    0xaf8d000 – 0xaf9efe3 com.apple.FinalCutPro.Plugins.FilterCustomEd 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
    0xafa3000 – 0xafb8fdf com.apple.FinalCutPro.Plugins.FilterViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
    0xafbd000 – 0xafc0fcf com.apple.FinalCutPro.Plugins.FinalTouchExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
    0xafc5000 – 0xafe5fcb com.apple.FinalCutPro.Plugins.Flash 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
    0xaff5000 – 0xb002fc7 com.apple.FinalCutPro.Plugins.GenViewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
    0xb007000 – 0xb00cff7 com.apple.FinalCutPro.Plugins.LayerFileReader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
    0xb010000 – 0xb05cff3 com.apple.FinalCutPro.Plugins.Media Manager 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
    0xb068000 – 0xb07cffb com.apple.FinalCutPro.Plugins.MolokiniSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
    0xb08b000 – 0xb09efff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
    0xb0aa000 – 0xb0befe7 com.apple.FinalCutPro.Plugins.Motion Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
    0xb0c3000 – 0xb0e1ff7 com.apple.FinalCutPro.Plugins.Movie Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
    0xb0f0000 – 0xb108ff3 com.apple.FinalCutPro.Plugins.Movie Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
    0xb114000 – 0xb119ffb com.apple.FinalCutPro.Plugins.NuggetExport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
    0xb11e000 – 0xb1c6fc3 com.apple.FinalCutPro.Plugins.OMF Audio Export 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
    0xb1e4000 – 0xb1ee027 com.apple.FinalCutPro.Plugins.Perf Analyzer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
    0xb1f3000 – 0xb20bfc1 com.apple.FinalCutPro.Plugins.ProAppsIntegration 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
    0xb21b000 – 0xb229fc3 com.apple.FinalCutPro.Plugins.Pulldown Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
    0xb231000 – 0xb27007b com.apple.FinalCutPro.Plugins.QTM Reader 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
    0xb27e000 – 0xb287feb com.apple.FinalCutPro.Plugins.QuickView 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
    0xb28b000 – 0xb29cfcb com.apple.FinalCutPro.Plugins.Relink Media 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
    0xb2a3000 – 0xb2a5fd7 com.apple.FinalCutPro.Plugins.Text Window 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
    0xb2a9000 – 0xb320fd5 com.apple.FinalCutPro.Plugins.Timeline Editor 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
    0xb32b000 – 0xb333fc7 com.apple.FinalCutPro.Plugins.Transcoder 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
    0xb338000 – 0xb34afff com.apple.FinalCutPro.Plugins.Transition Viewer 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
    0xb34f000 – 0xb365ff3 com.apple.FinalCutPro.Plugins.Trimming 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
    0xb36a000 – 0xb371fff com.apple.FinalCutPro.Plugins.VDUSupport 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
    0xb376000 – 0xb3b8067 com.apple.FinalCutPro.Plugins.Vector Accelerator 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
    0xb3be000 – 0xb3d0ff3 com.apple.FinalCutPro.Plugins.VideoLog 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
    0xb3d4000 – 0xb3edfff com.apple.FinalCutPro.Plugins.VoiceOver 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
    0xb3f3000 – 0xb456ffb com.apple.FinalCutPro.Plugins.XML Support 6.0.5 (6.0.5) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
    0xbb9a000 – 0xbbb1fe3 com.apple.fcp.DVOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
    0xbd63000 – 0xbe09ffb +com.blackmagic-design.BlackmagicCodec ??? (6.8.8) /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
    0xbe33000 – 0xbe48fd0 com.apple.FCP Uncompressed 422.component 1.5 (1.5) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xbe4d000 – 0xbea6feb com.apple.AppleProRes422 1.0.2 (46) /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
    0xbead000 – 0xbedffef com.apple.DVCPROHDCodec 1.4 (231) /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xbee4000 – 0xbf2ffff com.apple.viceroy.codec 32.1 (32.1) /System/Library/Components/VCH263Codec.component/VCH263Codec
    0xbf38000 – 0xbfd9fef com.apple.AppleHDVCodec 1.4.1 (222) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0xbfe7000 – 0xc007ffb com.apple.AppleVAFramework 4.1.14 (4.1.14) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0xc00d000 – 0xc02aff7 com.apple.AppleIntermediateCodec 1.2 (145) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xc02f000 – 0xc043ffb com.apple.IMXCodec 1.3.1 (147) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0xc048000 – 0xc0a5fff com.apple.applepixletvideo 1.2.16 (1.2d16) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xc0aa000 – 0xc0e8ff7 com.apple.QuickTimeFireWireDV.component 7.5.5 (995.22.3) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xc1c4000 – 0xc1c9fd7 com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
    0xc296000 – 0xc2c5feb com.apple.motion.MotionBundle 3.0.2 (3.0.2) <7c346e3fc9e94968a025c1f2937a9311> /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
    0xc400000 – 0xc453fdb com.apple.soundtrackpro.integration 2.0.2 () <062f0e6be76f4cdd9617eb09a89ec382> /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
    0xcb7d000 – 0xd2f6fe3 +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
    0xe0ff000 – 0xe10ffcb com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (1.2.3) /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
    0xe119000 – 0xe124fdf com.apple.PluginManager 1.7.3 (34) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0xe12f000 – 0xe140fe3 com.apple.fxplugframework 1.2.3 (1.2.3) /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0xe153000 – 0xe15efef com.apple.QuartzComposer.QCMotionPatch 1.0 (1.0) <7284ed9ae1d34b4f8868537255c5b8b5> /Library/Application Support/ProApps/Internal Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
    0xe178000 – 0xe179fdb com.apple.compressor.stomp 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Compressor
    0xe19d000 – 0xe1a2fcf com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    0xe1a9000 – 0xe1abfc7 com.apple.Helium 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    0xe1ae000 – 0xe1ecfe7 com.apple.Helium.HeliumRender 1.0.2 (1.0.2) /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0xe25e000 – 0xe262fff com.apple.audio.AudioIPCPlugIn 1.0.5 (1.0.5) <6d30b26789325677bbd205ccdbe755e7> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0xe284000 – 0xe285ffd com.apple.aoa.halplugin 2.5.7 (2.5.7f1) <8217e492adf5f0f7cdf567e92025442c> /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
    0xe2b9000 – 0xe2c6fe3 com.apple.fcp.TundraOutputUnit 1.3 (1.3) /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
    0xe400000 – 0xeb77feb +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
    0xf800000 – 0xf913ff6 com.apple.motion.filters 3.0.2 (3.0.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
    0xf972000 – 0xf9ee03f com.apple.DVCPROHDAudio 1.3 (1.3) /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    0xfa1e000 – 0xfa83fdb com.apple.DVCPROHDMuxer 1.3 (1.3) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0xfaa1000 – 0xfacdffb com.apple.mio.DAL.AVC 13.0 (13.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Resources/AVC.plugin/Contents/MacOS/AVC
    0xfb42000 – 0xfb49ffb com.apple.DesktopVideoOut 1.2.4 (1.2.4) /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    0xfb61000 – 0xfb68fff com.apple.IOFireWireAVCLib 2.2.3 (2.2.3) <8ccd4bc1d46d6b3f5d4ef03173ac35b1> /System/Library/Extensions/IOFireWireAVC.kext/Contents/PlugIns/IOFireWireAVCLib.plugin/Contents/MacOS/IOFireWireAVCLib
    0xfb8d000 – 0xfb9effb com.apple.DVCPROHDVideoOutput 1.3 (1.3) /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    0xfbac000 – 0xfbae05b com.apple.qmaster.swamp 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
    0xfbd5000 – 0xfbdffff com.apple.IOFWDVComponents 1.9.5 (1.9.5) /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    0xfbe9000 – 0xfbf1ff7 com.apple.compressor.FilterUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
    0xfe1a000 – 0xfe51fe7 +ProMath ??? (???) <7ea3110cdf8e4aefb2aeea82d0453a2f> /Users/edit3/Library/Frameworks/ProMath.framework/Versions/A/ProMath
    0xfe65000 – 0xff15fef +ProCore ??? (???) <26b08ee4ead6455ea96d80a2c64a9300> /Users/edit3/Library/Frameworks/ProCore.framework/Versions/A/ProCore
    0xff61000 – 0xff7bfdb +ThirdPartyPlugins ??? (???) <425f45a6ff71487884d356ae9c3ed3b7> /Users/edit3/Library/Frameworks/ThirdPartyPlugins.framework/Versions/A/ThirdPartyPlugins
    0x10000000 – 0x10062fc7 com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x100a7000 – 0x10136fef +ProMedia ??? (???) <53809068a8544f2d86b7747364047a1f> /Users/edit3/Library/Frameworks/ProMedia.framework/Versions/A/ProMedia
    0x101bb000 – 0x10222fef +ProGraphics ??? (???) <868f3f493b1a4080a86f4b18eb6b770a> /Users/edit3/Library/Frameworks/ProGraphics.framework/Versions/A/ProGraphics
    0x1030f000 – 0x10478fe8 +Lithium ??? (???) <529e95c925134095afff5899749fca29> /Users/edit3/Library/Frameworks/Lithium.framework/Versions/A/Lithium
    0x10515000 – 0x106bffff com.apple.motion.TextFramework 3.0.2 (3.0.2) <5dea579b1ea64a76bd33c9ec58e97fed> /Applications/Motion.app/Contents/Frameworks/TextFramework.framework/TextFramework
    0x108bb000 – 0x1090ffd3 +Bloodhound ??? (???) /Users/edit3/Library/Frameworks/Bloodhound.framework/Versions/A/Bloodhound
    0x10971000 – 0x10af1fe7 com.apple.motion.Behaviors 3.0.2 (3.0.2) <95cc336d8ff7424bb4c0bf540c20f3a1> /Applications/Motion.app/Contents/PlugIns/Behaviors.ozp/Contents/MacOS/Behaviors
    0x10bae000 – 0x10d25fff com.apple.motion.Particles 3.0.2 (3.0.2) <1d5675315f5e4242b7c8d0fc55eed54d> /Applications/Motion.app/Contents/PlugIns/Particles.ozp/Contents/MacOS/Particles
    0x10d8f000 – 0x10d9dfe3 com.apple.motion.Text 3.0.2 (3.0.2) /Applications/Motion.app/Contents/PlugIns/Text.ozp/Contents/MacOS/Text
    0x10db7000 – 0x10dbc03f com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0x10dc3000 – 0x10dc6fc7 com.apple.Helium.HCache 2.1.2 (2.1.2) /System/Library/PrivateFrameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0x10de0000 – 0x10decfdb com.apple.compressor.MediaServerAPI 3.0.5 (3.0.5) /Library/Frameworks/MediaServerAPI.framework/MediaServerAPI
    0x10fc5000 – 0x10ff0ffb com.apple.audio.SoundManager.Components 3.9.3 (3.9.3) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0x11000000 – 0x11016ff7 com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
    0x1102c000 – 0x117a1fff +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
    0x121f2000 – 0x1296bffb +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
    0x1355d000 – 0x1357bfff com.apple.IOFireWireLib 3.4.6 (3.4.6) <2676a17bbf7fda862daa8e424c9e0a07> /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
    0x13749000 – 0x1378cff3 com.apple.compressor.ImageProcessing 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
    0x137c2000 – 0x137cfff7 com.apple.compressor.StompUtil 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
    0x137dd000 – 0x137e9ff3 com.apple.qmaster.SwampUtil 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
    0x14000000 – 0x149e9ff0 com.apple.ozone.framework 3.0.2 (3.0.2) /Applications/Motion.app/Contents/Frameworks/Ozone.framework/Ozone
    0x14fbe000 – 0x150ad86f com.apple.AECore 3.0.5 (3.0.5) /Library/Frameworks/AECore.framework/Versions/A/AECore
    0x15142000 – 0x1522dff7 com.apple.compressor.StompTypes 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
    0x152cb000 – 0x1542efef com.apple.compressor.transcoding 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
    0x15540000 – 0x1558efef com.apple.compressor.StompUI 3.0.5 (3.0.5) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
    0x155bd000 – 0x155d8ff9 com.apple.audio.CoreAudioKit 1.5 (1.5) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x155e9000 – 0x15630018 com.apple.qmaster.SwampCore 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
    0x15674000 – 0x156b8fef com.apple.qmaster.SwampTypes 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
    0x156fe000 – 0x1574cfdf com.apple.qmaster.do 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
    0x157a1000 – 0x157acfcf com.apple.qmaster.SwampService 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
    0x157bc000 – 0x157cdfd7 com.apple.qmaster.Status 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
    0x157e8000 – 0x157f5fe7 com.apple.qmaster.RequestProcessing 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
    0x15809000 – 0x1581dfd3 com.apple.qmaster.ServiceControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
    0x15837000 – 0x15880fe3 com.apple.qmaster.ContentControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
    0x158bc000 – 0x158caff3 com.apple.qmaster.ClusterManager 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
    0x158dc000 – 0x158fcfd3 com.apple.qmaster.SwampUI 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
    0x15918000 – 0x15925fdb com.apple.qmaster.SwampExecutor 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
    0x24ac2000 – 0x24b8afef com.apple.qmaster.JobControl 3.0.5 (3.0.5) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
    0x2e325000 – 0x2e591ffb +org.perian.Perian 1.1.3 (1.1.3) <38385e8744cdb5a10099f319795c93de> /Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0x2e822000 – 0x2ea5dfcf +net.telestream.wmv.import 2.2.1.11 (2.2.1.11) /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0x2ea95000 – 0x2ec4affb +net.telestream.wmv.advanced 2.2.1.11 (2.2.1.11) /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0x2ee54000 – 0x2ee60ffe com.apple.URLMount 3.1.1 (3.1.1) /System/Library/PrivateFrameworks/URLMount.framework/URLMount
    0x300a7000 – 0x300adfff libCGXCoreImage.A.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    0x70000000 – 0x700cdff3 com.apple.audio.units.Components 1.5.2 (1.5.2) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
    0x8fe00000 – 0x8fe30c23 dyld 97.1 (???) <8dc1fc6c74fe1f055be16980dd45001e> /usr/lib/dyld
    0x90003000 – 0x90030fff libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x90031000 – 0x90036fff com.apple.CoreMediaAuthoringPrivate 1.5 (1.5) /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate
    0x90037000 – 0x9021dffb com.apple.security 5.0.4 (34102) <93e74504c60b38418e708caf47342cf5> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x9021e000 – 0x90463ffb com.apple.Foundation 6.5.7 (677.22) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x90527000 – 0x90587fff com.apple.CoreText 2.0.3 (???) <4ce8460abbfca7c9bd655ae0173976df> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90588000 – 0x9059bfff com.apple.LangAnalysis 1.6.4 (1.6.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x9059c000 – 0x9067ffff libobjc.A.dylib ??? (???) <39035ba996e55c617e20595dcd89c063> /usr/lib/libobjc.A.dylib
    0x90680000 – 0x9068bffb libgcc_s.1.dylib ??? (???) /usr/lib/libgcc_s.1.dylib
    0x9068c000 – 0x90697ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x90698000 – 0x906afffb com.apple.ImageCapture 5.0.1 (5.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x906b0000 – 0x906edfff libRIP.A.dylib ??? (???) <662becbd3173fd67eec7ad523d2d9c56> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x906ee000 – 0x906faff3 com.apple.audio.SoundManager 3.9.2 (3.9.2) <79588842bcaf6c747a95b2120304397a> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x90725000 – 0x907dffff libcrypto.0.9.7.dylib ??? (???) <335916b82e302fec637432caf7c9e8e5> /usr/lib/libcrypto.0.9.7.dylib
    0x907e0000 – 0x907e6fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <8b5a3065a2f06a46b4dde23faff6a20e> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x907e7000 – 0x907e9ffd libRadiance.dylib ??? (???) <34cc3c24f4be3a4372275400b6e05b85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x907ea000 – 0x90831fff com.apple.NavigationServices 3.5.2 (163) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x90832000 – 0x90867ffb com.apple.LDAPFramework 1.4.5 (110) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x90f4b000 – 0x91284ffb com.apple.HIToolbox 1.5.4 (???) <9624d2ffaf16019b6301517339df88c9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x91297000 – 0x9129dffb com.apple.backup.framework 1.0 (1.0) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x9129e000 – 0x91337fc3 libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x91486000 – 0x914c9fff com.apple.CoreMediaIOServicesPrivate 13.0 (13.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x914ca000 – 0x9150cfff com.apple.quartzfilters 1.5.0 (1.5.0) <3f2dc01a646cd5b5ea55d510583ba4d5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x9150d000 – 0x91c82fff com.apple.AppKit 6.5.6 (949.43) <3afcaa243535d0817efeb978448ef3dc> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x91c83000 – 0x91c9bffb com.apple.DictionaryServices 1.0.0 (1.0.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x91cb2000 – 0x91d19ffb libstdc++.6.dylib ??? (???) /usr/lib/libstdc++.6.dylib
    0x91d1a000 – 0x91d2dffb com.apple.speech.synthesis.framework 3.7.1 (3.7.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x91d2e000 – 0x91d36fff libbsm.dylib ??? (???) /usr/lib/libbsm.dylib
    0x91d8b000 – 0x91df0ffb com.apple.ISSupport 1.7 (38.2) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x91df1000 – 0x91df8ffb com.apple.print.framework.Print 218.0.2 (220.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x91df9000 – 0x91ebeffb com.apple.CoreData 100.1 (186) <9cf54cb19b18e53ee22edb7ababa6e6c> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x91ebf000 – 0x91ef0fff com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x91ef1000 – 0x91ef1ffc com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <91aadd6dccda219dd50a6ce06aad5b54> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x91ef2000 – 0x91f1afff libxslt.1.dylib ??? (???) /usr/lib/libxslt.1.dylib
    0x91f1b000 – 0x91f36ffb libPng.dylib ??? (???) <248297ff5b022c274d5dcfa0de3b37b2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91f3d000 – 0x91fd1ff7 com.apple.framework.IOKit 1.5.1 (???) <498f2ba1b47432ee4deebca2655ff932> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x91fd2000 – 0x920e6ffa com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x920e7000 – 0x9216fffb com.apple.audio.CoreAudio 3.1.1 (3.1.1) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x92170000 – 0x9223ffff com.apple.ColorSync 4.5.1 (4.5.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x92240000 – 0x923acff9 com.apple.AddressBook.framework 4.1.1 (699) <3334680563e5e0238454a586032b401b> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x923ad000 – 0x923b1ffe libGIF.dylib ??? (???) <491b205a6b8bb0c0c6ee6aaeea19a671> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x923b2000 – 0x923e7fff com.apple.AE 402.2 (402.2) <0b15a08da8ec38b74fb9dd6e579ed25f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x923e8000 – 0x9241afff com.apple.bom 9.0.1 (136.1.1) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x9241b000 – 0x9241bfff com.apple.Carbon 136 (136) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x9241c000 – 0x92497fff com.apple.SearchKit 1.2.1 (1.2.1) <23c2c93a7ec832505d5c7b67fee89a6d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x924d8000 – 0x92588fff com.apple.QD 3.11.54 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x92594000 – 0x92734fe3 libSystem.B.dylib ??? (???) <3260ab8c558e938c8180b3ba1036aec1> /usr/lib/libSystem.B.dylib
    0x92735000 – 0x9281efff libxml2.2.dylib ??? (???) /usr/lib/libxml2.2.dylib
    0x9281f000 – 0x92838ffb com.apple.CoreVideo 1.5.1 (1.5.1) <43996b088c16cd1fb1223bcfabc3c366> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x92839000 – 0x92846fff libbz2.1.0.dylib ??? (???) /usr/lib/libbz2.1.0.dylib
    0x92847000 – 0x9284afff com.apple.help 1.1 (36) <7106d6e074a3b9835ebf1e6cc6c822ce> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x9284b000 – 0x92dc7ff7 com.apple.CoreGraphics 1.407.2 (???) <6a101d8218dc8d12ca0b901c57aa44b7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x92dc8000 – 0x92dc8fff com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x92eca000 – 0x92fefffb com.apple.CoreFoundation 6.5.5 (476.17) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x92ff0000 – 0x93355ffe com.apple.QuartzCore 1.5.7 (1.5.7) <75a8ef92c54d1ce016dfe662a6626f04> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x93356000 – 0x93374fff com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x93375000 – 0x9340fff7 com.apple.ApplicationServices.ATS 3.4 (???) <06af1441f632e171a7f61dca809462ba> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x93410000 – 0x93410ffa com.apple.CoreServices 32 (32) <42b6dda539f7411606187335d9eae0c5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x93411000 – 0x93437fff libcups.2.dylib ??? (???) /usr/lib/libcups.2.dylib
    0x93438000 – 0x93471fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <1a39075165bf7447fe8be1e93db49346> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x93472000 – 0x934dcfff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x934dd000 – 0x9358bffb com.apple.QTKit 7.5.5 (995.22.3) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x9358c000 – 0x9360dfff com.apple.print.framework.PrintCore 5.5.3 (245.3) <032f772f8169945c1d1b524d96edcef6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x937a0000 – 0x937bffff com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x937c0000 – 0x9380afff com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x93849000 – 0x93869ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x9386a000 – 0x93a0aff7 com.apple.QuartzComposer 2.1 (106.13) <729b5ad0c523a74307cd23a7c3282e0d> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x93a0b000 – 0x93a27ffb com.apple.openscripting 1.2.8 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x93a28000 – 0x93d2affb com.apple.CoreServices.CarbonCore 786.10 (786.10) <3861a1af8d647c75688761d7ef4b5bf3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x93d2b000 – 0x93d2cff8 com.apple.ApplicationServices 34 (34) <6aa5ee485bb2e656531b3505932b845f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x93d2d000 – 0x93e75ffb libicucore.A.dylib ??? (???) /usr/lib/libicucore.A.dylib
    0x93e76000 – 0x93e81fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <817174777f7b41bfa3e0cc8974fffbdc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x93e9f000 – 0x93f24fff libsqlite3.0.dylib ??? (???) /usr/lib/libsqlite3.0.dylib
    0x93f25000 – 0x93f25fff com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x93f26000 – 0x93f34fff libz.1.dylib ??? (???) <1a70dd3594a8c5ad39d785af5da23237> /usr/lib/libz.1.dylib
    0x93f35000 – 0x93f92ffb com.apple.HIServices 1.7.0 (???) <5f468086ca01158e12cd07f829132edf> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x93f93000 – 0x93ff5ffb com.apple.htmlrendering 68 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x93ff6000 – 0x9409fffc com.apple.CFNetwork 422.11 (422.11) <189498280742bb4579e91b165301d331> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x940a0000 – 0x940a0ffe com.apple.quartzframework 1.5 (1.5) <1477ba992c53f43087c7527c4782fd54> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x940a1000 – 0x94109fff com.apple.iLifeMediaBrowser 1.0.11 (212.1.1) /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x9410a000 – 0x94200ffc libiconv.2.dylib ??? (???) <05ae1fcc97404173b2f9caef8f8be797> /usr/lib/libiconv.2.dylib
    0x94201000 – 0x9452ffff com.apple.QuickTime 7.5.5 (995.22.3) <98ef03eeecac6f0776bab73509f26c79> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x94530000 – 0x94677ffb com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x94678000 – 0x946a1ffb com.apple.shortcut 1 (1.0) <032016a45147a2f3f191ce70187587c9> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x946a2000 – 0x94752fff edu.mit.Kerberos 6.0.12 (6.0.12) <17b514ffed29c890fc8ba8eac9dce56e> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x94753000 – 0x94d0dfff libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x94d0e000 – 0x94d0eff8 com.apple.Cocoa 6.5 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x94d0f000 – 0x94d65fff libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x94d66000 – 0x94df5ffb com.apple.DesktopServices 1.4.7 (1.4.7) <5792e9dc03f76544c71dedd802a1fa36> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x94df6000 – 0x94e06ffb com.apple.agl 3.0.9 (AGL-3.0.9) <056d952943aac260426645ce6a24eb9e> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x94e07000 – 0x95130fe7 libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x95131000 – 0x95150fff libresolv.9.dylib ??? (???) /usr/lib/libresolv.9.dylib
    0x95151000 – 0x95224fff com.apple.CoreServices.OSServices 226.5 (226.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x9522b000 – 0x9522cfff libffi.dylib ??? (???) <11b77dbce4aa0f0b66d40014230abd1d> /usr/lib/libffi.dylib
    0x9522d000 – 0x9523afff libCSync.A.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9523b000 – 0x95243ffb libCGATS.A.dylib ??? (???) <0c83819d2d428a8df27c8cc0f13ba1dc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x95244000 – 0x95244ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
    0x95245000 – 0x95255fff libsasl2.2.dylib ??? (???) /usr/lib/libsasl2.2.dylib
    0x95256000 – 0x95280ff7 libssl.0.9.7.dylib ??? (???) <1c571a24294df1af3428e31d464029fc> /usr/lib/libssl.0.9.7.dylib
    0x95281000 – 0x9530bfff libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x9530c000 – 0x95337ff7 libauto.dylib ??? (???) /usr/lib/libauto.dylib
    0x95338000 – 0x95387fff libGLImage.dylib ??? (???) <1df480344fb6e09ff32ac97bfdda7e50> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x95388000 – 0x953b1fff com.apple.CoreMediaPrivate 13.0 (13.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x953b2000 – 0x953b5ffb com.apple.securityhi 3.0 (30817) <08b7dd59bdfadfc2e73cd708bb8bdc31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x953b6000 – 0x95457ff7 com.apple.QuickTimeImporters.component 7.5.5 (995.22.3) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
    0x95458000 – 0x95473ff3 com.apple.DirectoryService.Framework 3.5.5 (3.5.5) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x95474000 – 0x954c3fff com.apple.Metadata 10.5.2 (398.25) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x954c4000 – 0x954e3fff com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x957ab000 – 0x957b4fff com.apple.DiskArbitration 2.2.1 (2.2.1) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x957b5000 – 0x957bcfff com.apple.CommonPanels 1.2.4 (85) <0d1256175c5512c911ede094d767acfe> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x957bd000 – 0x958e2ffb com.apple.imageKit 1.0.2 (1.0) <139eccda7bd9529a258fdb6f092b11b0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x958e3000 – 0x959b1ffb com.apple.QuickTimeMPEG4.component 7.5.5 (995.22.3) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x959b2000 – 0x95de0ffa libGLProgrammability.dylib ??? (???) <2c52a11697da6ede976b56d54e3815ef> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x95de1000 – 0x95df0fff com.apple.DSObjCWrappers.Framework 1.3 (1.3) <897487778bd1c0429fcd88c99c293583> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x95e23000 – 0x96b4afef com.apple.QuickTimeComponents.component 7.5.5 (995.22.3) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x96b4b000 – 0x96be1fff com.apple.LaunchServices 290.3 (290.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x96be2000 – 0x96bf0ff3 com.apple.opengl 1.5.9 (1.5.9) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x96bf1000 – 0x96cd9fff com.apple.JavaScriptCore 5525.26 (5525.26.2) <3a03d36ac807322bc73ed78c515e32be> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x96cda000 – 0x96d1bffb libTIFF.dylib ??? (???) <4c1422124af245485d6ceee207f4d735> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x96d82000 – 0x96e0afff com.apple.ink.framework 101.3 (86) <66a99ad6bc695390a66dd24789e23dcc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x96e5a000 – 0x96e5fff6 libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
    0x96e60000 – 0x96faaffb com.apple.ImageIO.framework 2.0.4 (2.0.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0xfffec000 – 0xfffeffff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
    0xffff8000 – 0xffff9703 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    Jeremy Garchow replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    April 1, 2009 at 6:54 pm
    Looks like you are trying to caputre from an FX1 and perhaps you have a fw drive on that separate PCI board, or maybe you the firewire drive and FX1 on the same bus?
    Something in your firewire system crashed there.
    What else is in your system PCI card wise?
