Activity › Forums › Apple Final Cut Pro Legacy › FCP Craps out when loading TIFF
  • FCP Craps out when loading TIFF
    Posted by Matt Soble on March 15, 2006 at 5:54 pm
    Hey there everybody, I’ve got a question. I am editing a video where I’m using screen caps of emails. I have been using SnapZPro and saving them as tiffs. But everytime I load them into the source window, FCP craps out. I’m running 4.5 on 10.3.9 (as of now).
    The workaround seems to be upping the dpi to 100, from 72. But why, oh why, would 72 dpi be a problem since that is standard for video? Any help on this subject would be greatly appreciated.
    “For three days after death, hair and fingernails keep growing. The phone calls taper off, though.
    – Johnny Carson
    Debe replied 20 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • David Roth weiss
    March 15, 2006 at 7:13 pm
    Don’t save as TIFFs, try PNGs.
  • scottwitt Scott witt
    March 15, 2006 at 8:10 pm
    Isnt PSD the better ones to use?
  • David Roth weiss
    March 15, 2006 at 8:15 pm
    There’s no reason to use a PSD if you have no layers.
  • Matt Soble
    March 15, 2006 at 8:39 pm
    I tried the PNG and that didn’t work either. I wonder if it could be Snapz? Like I said, when I bump up to 100 dpi, everything’s fine. It’s so weird.
    – Johnny Carson
  • Steve Eisen
    March 16, 2006 at 1:31 pm
    Make sure your image is RGB.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Matt Soble
    March 16, 2006 at 3:23 pm
    I’ve done that many times (left it as CMYK). It won’t even import if that’s the case. Here’s what’s strange. Last time this happened, I bumped the files up from 72 dpi to 100 dpi and it worked. This time, it didn’t work until I dropped it to 40 dpi, which, of course, isn’t good enough for what I need to do.
    We are going to try adding RAM to see if that works. I’ll keep everyone posted.
    – Johnny Carson
  • Debe
    March 16, 2006 at 7:01 pm
    [mattso] “left it as CMYK”
    I may be misreading this, but you do understand that it MUST be RGB?
    CMYK is a print format, and doesn’t translate into video.
    debe
  • Matt Soble
    March 16, 2006 at 8:02 pm
    I was saying I’ve made that mistake before. This time, though, it is RGB. 100 dpi.
    – Johnny Carson
  • Debe
    March 16, 2006 at 8:05 pm
    Oh, ok…so I did read it wrong!!
    Wish I had an answer for you. It sounds like it should work with no issues.
    debe
