Activity Forums Apple Final Cut Pro Legacy FCP configuring for Kona 3
  • FCP configuring for Kona 3
    Posted by Dan Mirolli on July 26, 2007 at 9:23 pm
    Hello,
    Just rented a panasonic DVCPOHD deck and want to dump footage into my G5/Medea RAID.
    We do alot of DVCPRO50, but this is the first HD. Sucessfully dumped a little footage from HD camer via Firewire into system using DVCPRO HD codec.
    Now I’m running the HD deck to the KONA3 via SDI and can see and control the deck in FCP.
    Problem occurs when I try to digitize. Using Pro res or Pro Res HQ I get dropped frames. In Kona3 DVCPro HD I get a error saying “attempting to capture video without video device selected” . . . . I know I’m overlooking something . . but I’ve been going round and round and was wondering if anyone would share their exact settings.
    thanks
    Walter Biscardi replied 19 years, 2 months ago 5 Members · 6 Replies
  • Jonny Hal
    July 26, 2007 at 9:50 pm
    I’m running FCP Studio 2 with a Kona 3 and am getting dropped frames on any clip over 2 seconds.
    The deck is a Sony J-H3. I’m thinking the problem might be that I don’t have triple sync running between the two.
    Setting the reference to either Video In or Free run has no effect.
    I’ve tried Kona 1080i 10-bit and the Kona 1080i Pro Res — same problem.
    You are not alone.
    jHal
  • Jeremy Garchow
    July 26, 2007 at 9:58 pm
  • Dan Mirolli
    July 26, 2007 at 10:01 pm
    Thanks guys,
    Yeah Jeremy, I knew that and my G5 is up to it. Even if i can’t make the ProRes work, the DVCPRO HD should work through the KONA 3. Should it not ?
  • Jeremy Garchow
    July 26, 2007 at 10:17 pm
    Most definitely.
  • David Roth weiss
    July 26, 2007 at 10:44 pm
    [jonnyHal] “I’m running FCP Studio 2 with a Kona 3 and am getting dropped frames on any clip over 2 seconds.
    The deck is a Sony J-H3. I’m thinking the problem might be that I don’t have triple sync running between the two.”
    You don’t need sync for capture — Genlock in the control panel should be set for Video In.
    What type of drives are you capturing to?
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Walter Biscardi
    July 27, 2007 at 12:09 pm
    [dan] “Yeah Jeremy, I knew that and my G5 is up to it. Even if i can’t make the ProRes work, the DVCPRO HD should work through the KONA 3. Should it not ?”
    Yes. If you can’t capture DVCPro HD then you have a throughput problem with your drives. Even a FW400 drive can capture / playback DVCPro HD.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
