Activity Forums Apple Final Cut Pro Legacy fcp compressor no interlace
  • fcp compressor no interlace
    Posted by Jurriaan Van der kamp on May 27, 2010 at 11:02 am
    Hi
    I want to make a h264 from a qt straight out of my fcp timeline.i made a quicktime movie preset. so: quicktime movie.h264 frame rate 25 key frames automatic,compressor quality medium, multi pass on.in the third tab (frame controls) you can choose to deinterlace and a bumch of other stuff. I have this whole checkbox switched off. Jet it makes prograssive h264 movies? If i use the same settings using quicktime instead of comressor it works fine? can someone please explain. thanx
    Jurriaan Van der kamp replied 16 years, 3 months ago 2 Members · 2 Replies
  • John Fishback
    May 27, 2010 at 7:41 pm
    I’m not sure if this is the answer, but if you turn ON Frame Controls – in the Resizing control you’ll see a selection of Top & bottom fields in Output Fields. Try setting that to Upper (for PAL) and see if it makes an interlaced output. I know that if you’re resizing the image you’ll get much better (if slower) results with Frame Controls on and the Resize Filter set to Better or Best.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jurriaan Van der kamp
    May 27, 2010 at 8:46 pm
    thanks for you response. But what do i choose in the the deinterlace box i have 4 choises: fast,better best and reverse?
