Activity Forums Apple Final Cut Pro Legacy FCP compression export — picture edit does not match
  • FCP compression export — picture edit does not match
    Posted by Nick Miede on February 2, 2009 at 11:53 pm
    One part of my picture edit in my FCP timeline is different when I export (this has happened with multiple file formats now). Specifically, I am seeing the same picture length, just a later in/out from the original logged/captured picture. I have no idea what the problem is or how to fix it though b/c I see exactly what I want to in the timeline. Anyone else have this problem or have ideas as to what it could be and how I could address it?
    Nick Miede replied 17 years, 7 months ago 2 Members · 2 Replies
  • David Bogie
    February 3, 2009 at 12:03 am
    Export to what?
    Try this, export a self-contained movie using the sequence settings.
    View it, Is it okay? If so, take it to Compressor. If not, post back
    bogiesan
  • Nick Miede
    February 3, 2009 at 12:27 am
    I exported straight to compressor for an mpeg-2. Then burned in DVDSP. All picture came out exactly they way I wanted except for this 1 clip, which starts at a later timecode (from the log/capture) in the exported file than is showing in the FCP timeline…? I want what is showing in the timeline. Does this help clear things up at all?
