Activity Forums Apple Final Cut Pro Legacy FCP completely ignorant about rendered media- bug or SOP?
  • FCP completely ignorant about rendered media- bug or SOP?
    Posted by Cory Caplan on September 5, 2007 at 3:47 pm
    I have a 2 hour timeline with audio which shouldn’t have to be rendered anyway– it’s dv media which was captured via firewire using a dv preset in a “dv preset” timeline. However, for whatever reason, some clips, but not all are showing up with an “aud rate” of 47999.6 instead of 48k (wtf??) Anyway, When I render the timeline, (with a nested sequence) and make an edit that doesn’t affect the clip at all (ie, move it up or down in the sequence) the entire thing becomes unrendered. Is this SOP? It seems insane that FCP has no ability to keep track of when you need to rerender media. (And loses track of rendered media for no apparent reason. This is totally broken, right??
    Cory
    David Roth weiss replied 18 years, 12 months ago 2 Members · 3 Replies
  • David Roth weiss
    September 5, 2007 at 4:11 pm
    Because of your audio anomaly your media does not match your timeline. I’ve seen the same deal with some tapes shot with a Pnay camera. The best solution is to covert your media to DV with 48khz audio using QT conversion or possibly media manager.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Cory Caplan
    September 5, 2007 at 4:28 pm
    Does it know not to transcode the video? I surely wouldn’t want to recompress my dv just because somewhere there’s a glitch in the process.
    Interesting you say panasonic. I use a panasonic (2500?) deck to ingest, but the footage came from a sony DVCAM initially.. Never had problem #1 with my avid and this config… So I assume it’s a bug (#4007 I’ve encountered in my 6 weeks since switching) The grass is always greener….
    Cory
  • David Roth weiss
    September 6, 2007 at 4:12 am
    In theory, if you’re using QT conversion and converting to the same video format there should be no compression involved. I’m fairly certain that’s the case.
    BTW, for the record, I had the problem with a Pany deck too, but I assumed it was the camera. I’ll bet its the deck.
    David Roth Weiss
    Director/Editor
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY ?
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
