Activity Forums Apple Final Cut Pro Legacy FCP Capturing Numerous TimeCode Breaks Sony FX1 to Sony DSR-PD100a
  • FCP Capturing Numerous TimeCode Breaks Sony FX1 to Sony DSR-PD100a
    Posted by Amber Kim on January 19, 2009 at 7:51 pm
    Mac Book Pro 15in?
    Mac OS x 10.4.11
    2.4 GHz Intel Core 2 Duo
    2GB 667 MHz DDR2 SDRAM
    FCP 6.0.5
    Camera Tape was recorded from: Sony HD Fx1
    Capture Camera: Sony DSR-PD100a
    Tapes: Maxell mini DV
    Standard Definition
    SP and 48khz
    JVC mini DV Digital Video Cleaning Cassette
    Capture Camera and hard drive connected directly to my computer
    When I capture, there are usually numerous timecode breaks that last for about 5 seconds each. I know it’s not the way they were recorded since the counter does not reset nor does the cameraman start a new clip.
    FCP pro either tries to locate a timecode break or tells me that there is a problem with the tape, but this has happened with numerous tapes recorded from the same camera (other tapes recorded with a different, consumer camera have no problems). There are no problems when capturing from the original camera that recorded the tapes, but my problem is that I telecommute and I have to use the PD-100a.
    I’ve tried using a tape head cleaner – the only one I could find in my area, and it doesn’t seem to make a difference. Capture Now doesn’t change things either, nor capturing with an uncontrolled source.
    I know I’ve had a problem with footage recorded from PD-100 that I tried to capture with a consumer camera because of a way the PD-100 captures with more quality but less compatibility, but that problem was so bad that the consumer camera could only capture 1 frame at a time. I was wondering if the problem I’m having is similar and what I could do about it. I tried looking at the FX1’s manual and could not find any settings I could change.
    Thank you for your time and help.
    Amber Kim replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
