Activity Forums Apple Final Cut Pro Legacy FCP CAPTURED FILMS
  • FCP CAPTURED FILMS
    Posted by Ron Rothstein on August 29, 2008 at 9:38 pm
    In FCP Studio 2 when I capture, I’m getting get quicktime files where the Quicktime file name is followed by…… -1-av and -2-av and -3-av etc which, when clicked, brings up a message box that says “The movie could not be opened. This file is not a movie file! There is also the “real” file which only has -av next to it but no number and it can be opened and it works.
    What are all these other files… and do I need them and /or how can I not create them in the first place. It didn’t use to be this way… and yes the external drive is formatted to MAC OSX JOURNALING OFF…. not sure if that matters in this case.
    Can anyone tell me what I am doing wrong ????
    Ron
    Rafael Amador replied 18 years ago 5 Members · 6 Replies
  • Bill Dewald
    August 29, 2008 at 11:02 pm
    Check under System Settings – see if “Limit Capture/Export File Segment Size” is enabled.
    Cause it shouldn’t be.
    What type of footage are you capturing?
  • Walter Biscardi
    August 29, 2008 at 11:04 pm
    Sounds like you’re capturing Audio and Video separately. Capture them as one file.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Ron Rothstein
    August 29, 2008 at 11:26 pm
    I’m not capturing them separately. I am capturing them together unless my using preview (under clip settings audio) means it is being captured separately. I thought that was just so you can hear the audio as it is being captured…
  • Ron Rothstein
    August 29, 2008 at 11:31 pm
    Bill,
    Capturing MiniDV but, you’re right, I do have it checked and the capture/Export File Segment Size is listed at 2000MB.
    So I guess I should uncheck it. I will try that.
    Thanks.
  • Steve Eisen
    August 30, 2008 at 12:03 am
    Save your project before capturing.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Rafael Amador
    August 31, 2008 at 8:36 am
    By any chance do you have your external HD connected by USB?
    Rafael
    http://www.nagavideo.com
