FCP Capture Problems
Hi all,
I’m new to Creative Cow, seen it occasionally and thought I’d take the plunge and join. It seems like a great, highly professional resource.My facility just went into the video production business, using FCP. I’ve had a bit of training with it and feel comfortable capturing our classes and editing them for internal post and archive.
The current setup (2 halls identical) is: installed cameras sending 1080i images to a Panasonic AV-HS400A, program out from there sending SDI to a Multibridge Pro encoder for capture, then available for editing in FCP 7.01. We’ve also just added Matrox CompressHD cards for speedier compression. The problems described below occurred before we installed the Matrox cards.
Right now the capture window image is pink and unstable! We cannot capture the image before we get a “dropped frames” error and termination of the capture. What drives me nuts is that the system worked fine before last Tuesday. I WAS capturing in the Log & Capture window at 1080i 59.94-JPEG. Now I only get image at either 1080i59.94-Apple ProRes 4444 or 1080i 59.94-10 bit RGB 4.4.4.4.
I have a feeling we’ve messed up the output settings of the switcher somehow, or somehow damaged the Multibridge Pro. The switcher is sending imagery fine to the rest of the room systems, so I conclude the output is OK. I’ve looked at the Multibridge Preferences and reset the FCP preferences using the Apple Assistant. Neither has helped. Now I’m out of ideas.
Anyone experience this or similar problems? Any info gratefully appreciated. Please feel free to post direct if posting to the forums is a problem.
John
John Steele
Multimedia Production Coordinator
Armstrong Medical Education Building
Johns Hopkins University
