Activity › Forums › Apple Final Cut Pro Legacy › FCP Capture preview window always on top
  • FCP Capture preview window always on top
    Posted by Brandon Ridge on September 16, 2007 at 7:38 pm
    I’ve looked for the solution to this for some time and haven’t found anything, so I hope someone could help.
    With FCP 4.5 When you were capturing something you could switch to another program like after effects and all of Final cuts windows would be covered by the After Effects or whatever program you open. Now with FCP 5.0 The capture window is on top of everything. Is there a work around? This is a major slowdown to my workflow.
    Brandon Ridge
    Rafael Amador replied 19 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 18, 2007 at 9:38 am
    Click in the dock the thumbnail of the application you want to be on top of FC. Other solution is to click the FC thumbnail in the Dock and choose “hide”.
    Chers,
    Rafael
