Activity Forums Apple Final Cut Pro Legacy FCP Capture Not Working
  • FCP Capture Not Working
    Posted by Joseph Garner on January 15, 2009 at 9:02 am
    Hi. I shot HDV footage using the Sony V1U (24pA). I have the latest version of Final Cut (6.0.5) and I’m using a different Sony HDV camcorder to digitize the footage. The problem is the device is not recognized by Final Cut. I changed the settings to Apple ProRes 422 using Sony Firewire but it doesn’t allow or even recognize the camera.
    Is it possible that I need to use the same camera I shot with (V1U) to digitize the footage?
    Please help…
    Joe
    Andy Mees replied 17 years, 8 months ago 2 Members · 1 Reply
  • Andy Mees
    January 15, 2009 at 10:38 am
    Danger, Will Robinson! Messing with the settings if you don’t understand exactly what you’re doing will usually end in unexpected and unwanted results. (Apologies of course if you do understand exactly what you’re doing!)
    Your best bet is just to go to your Easy Setups and choose: HDV-Apple ProRes 422 1080p24
    See if that helps
