Activity › Forums › Apple Final Cut Pro Legacy › FCP Capture Issue
  • FCP Capture Issue
    Posted by Martin Tupperheim on October 7, 2008 at 4:05 am
    Hey all,
    I am new to FCP and am working on some recent projects so please be kind.
    I am running into issues where I capture from an AJA IO from a UVW-1800 and a Kona LHe from a Panasonic AJ-SD93. REGARDLESS of what I capture I am finding that I am getting blockiness/artifacting whenever I apply the de-interlace filter.
    Now I should mention that sometimes I capture Beta SP, DVCPro 50, 24p and 60i. I know that about 24p being progressive and I should incorporate the pulldown info from Cinema Tools. I do that.
    The problem I am running into is that regardless of what I am capturing and working with I get this blockiness/artifacting around the faces, heads, shoulders of people. Obviously I don’t apply the de-interlace filter on progressive footage but when I apply it on ALL other footage I get this. I have my settings within FCP (depending on what I capture) typically with fields set to none within the sequence. When the footage is captured it comes is as lower field first. I then de-interlace and get this artfacting.
    My question is… Do I need to set the sequence to “None” when it comes to fields or do I set it to lower field first? Also, do I make sure the footage is set to lower field first? What is the right combination for footage that needs de-interlaced? I will work on the problems I am having with progressive footage at a later date as I am getting this artifacting regardless of the footage – that’s what makes me believe it is a capture/sequence issue.
    I hope I am being clear and any help would be greatly appreciated.
    MT
    Follow your dreams. You can achieve your goals; I’m living proof… BEEFCAKE!
    Martin Tupperheim replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
