Activity › Forums › Apple Final Cut Pro Legacy › FCP Capture Blues – Sony J-H1 HDCam Deck
  • FCP Capture Blues – Sony J-H1 HDCam Deck
    Posted by Andy Gallun on December 5, 2011 at 5:40 pm
    Trying to get FCP 7.0 to recognize an old Sony J-H1 HDCAM deck. I’ve played with the Capture/Device Control settings with no avail. Changed cables and different firewire (400 vs. 800) ports on the computer, also with no luck.
    Any thoughts?
    Someone told me that you can only capture SD out of the firewire port on this deck. Is there any truth to that? At this point I will take SD over nothing, but the full HD would be better.
    The following is the info on the computer that we are trying to capture to:
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 8 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version (system): 1.25f4
    Thanks in advance for your help!
    Andy
    Andrew Gallun
    Sleeping Dog Productions
    http://www.sleepingdogtv.com
    The Leader In Aviation Television Production
    Shane Ross replied 14 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Fred Miller
    December 5, 2011 at 6:02 pm
    You may have to turn on the firewire connection on the deck through the menu on the deck. I think it’s called i.LINK. I don’t know for sure, but I’m guessing that you are correct about SD only through the firewire.
    FCP Studio 2
    Dual 3Gg Quad Core
    4Gg RAM
    KONA 3
    OS 10.5.8
  • Shane Ross
    December 5, 2011 at 6:33 pm
    Via firewire you will only get DV, as a matter of fact. The lowest format of SD. And you won’t get deck control…only a video signal. So it will have to be an UNCONTROLLED DEVICE setting for this, and you’ll have to manually control the deck.
    Shane
    Little Frog Post
  • Shane Ross
    December 5, 2011 at 6:34 pm
    And you might have to look in the settings to make sure that DV is set up to go out via firewire. It might default to it…but need to be sure.
    Shane
    Little Frog Post
  • Andy Gallun
    December 5, 2011 at 8:47 pm
    Thanks much for the replies. I was able to get deck control, but only with a 720×480 output. Looking into an internal capture card with component connections to get around this.
    Andrew Gallun
  • Steve Eisen
    December 6, 2011 at 1:40 am
    Capture i/o devices from Matrox, AJA and Black Magic are so affordable these days. Everyone should have them. You can even monitor your timeline via inexpensive LCD TV’s.
    External units you can use on both the Mac Pro and Mac Book Pro (firewire 800 or Express 34) and PCIe units just for the Mac Pro.
    With Thunderbolt units, you can connect to MBP and iMac.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Andy Gallun
    December 7, 2011 at 12:02 am
    Anybody have any experience with a BlackmagicDesign DeckLink Studio card? Looks like it will give us the ability to capture the HDCam tapes in true HD via component connections.
    Andrew Gallun
  • Shane Ross
    December 7, 2011 at 12:08 am
    [Andy Gallun] “Anybody have any experience with a BlackmagicDesign DeckLink Studio card?”
    Yes.
    [Andy Gallun] ” Looks like it will give us the ability to capture the HDCam tapes in true HD via component connections.”
    It will.
    Shane
    Little Frog Post
