FCP capture audio
I’m having some major audio problems with mini dv tape footage I have captured into FCP.
The audio issue is best described as a random “gargling” sound. It occurs sporadically, and after changing capture devices and firewire cables, still persists. The sound is not on the tape, and doesn’t show up during capture.It has started to frustrate the editing process, and require recapture of a lot of material.
Has anyone run into this problem before? I tried resetting my preferences in FCP. Waiting to see if that helps. Any advice is appreciated.
Thanks in advance.
