Activity Forums Apple Final Cut Pro Legacy FCP can’t see Z1
  • FCP can’t see Z1
    Posted by Ken Pugh on July 7, 2007 at 7:34 am
    (Cross-post from DV forum)
    I’ve been given a Z1 camera for my next shoot and I’m in trouble!
    FCP can see my Sony dsr 570 camera fine – but whatever I do I can’t get it to see the Z1.
    I’ve tried in Easy Setup PAL-DV with the camera set to DVCAM record and playback, and I’ve tried easy setup HDV with the camera set to HDV record and playback – but in every occaision FCP reports it can’t see the camera/deck.
    This is my first time using the Z1.
    Can anyone help – I’m flying out tomorrow!
    Ken.
    Ken Pugh replied 19 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Chris Poisson
    July 7, 2007 at 2:19 pm
  • 13 Create COW Profile Image
    13
    July 7, 2007 at 4:06 pm
    What version of FCP are you using?
  • Ken Pugh
    July 7, 2007 at 9:52 pm
    The latest – 6.0.1
    Sorry – should have said.
    Ken.
  • Ken Pugh
    July 7, 2007 at 9:55 pm
    >thanks for everybodys help. i had to turn off the downlink converter and also hook up my >camera first before turning on fcp. thanks again!
    Tried this – no joy. I suspect there may be a camera fault.
    Ken.
  • Matt Benda
    July 8, 2007 at 1:24 am
    hi ken,
    go into the Z1’s menu settings and make sure its set for pal 50i. your problem might be that its set for ntsc 60i. the Z1 shoots both.
    matt
  • Martin Gaxiola
    July 8, 2007 at 7:09 am
    Test the camera and the firewire cable (at least two different cables) on another computer. If the other computer still cannot recognize the camera, then there is probably issue with the firewire port on the camera (i.e. dead).
    I rented a Z1 and had the same problem on two different machines, two different platforms (TIger and Windows XP) and two different software pkgs (FCS3 and Adobe Premiere 2.0) The firewire port was bad and the video production company told me that happens alot when novice users plug/unplug the firewire cable while the unit is powered on (there is enough of a power surge in the line to short out the connection). When I swapped out the Z1 for a HVR-1500, all worked perfectly.
    Good luck!
  • Ken Pugh
    July 9, 2007 at 7:06 pm
    Thanks everyone – have tried all suggestions and think it is indeed a blown f/w connector.
    Best,
    Ken.
