Activity › Forums › Apple Final Cut Pro Legacy › fcp can’t “find” my external drive…
Posted by Donna Valenti on February 7, 2010 at 4:45 pmany ideas on what to do when final cut pro suddenly decides it can’t find your external drive, although your mac sees it… tried shutting down, total restart, connect, disconnect, you name it… recognized it last night, today they never met..
~DV
Jeremy Garchow replied 16 years, 7 months ago 6 Members · 6 Replies -
John Fishback
February 7, 2010 at 5:29 pmI’d trash prefs and repair permissions if you haven’t already tried that.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Robb Harriss
February 7, 2010 at 5:48 pmwithout knowing the chain of events:
You might have changed the name of the drive, or even hit the “forget reconnecting to these files” button. Try selecting one of the clips in your show and “reconnecting Media” and then navigating over to your external drive.Non-linear: all the time and nothing but.
Ken Jones
February 7, 2010 at 9:15 pmI have had a drive go to sleep and totally confuse FCP. I have read that this a common problem with some external drive manufacturers but not so much with others.
John Doggett-williams
February 8, 2010 at 2:22 amUnless the drive is really cooked you should be ok. It often happens with my cheaper drives, I usually just open Disk Utility, the drive icon may be there but not highlighted (if they’re not there highlight on the main drive) you then just click repair permissions, I’ve trashed my FCP permissions which worked but you should be aware you’ll need to redo your personal preferences and I think you loose any favourite you may have saved.
John doggett-williams
