Activity › Forums › Apple Final Cut Pro Legacy › FCP cannot open files in the “Final Cut Pro XML File” format
  • FCP cannot open files in the “Final Cut Pro XML File” format
    Posted by Mark Hubert on May 23, 2010 at 3:35 am
    I “sent” a sequence to Soundtrack Pro 3 for a mix. I then exported with the after export open in FCP sequence option selected.
    When it’s complete I get the error: The document “mastermix.xml” could not be opened. Final Cut Pro cannot open files in the Final Cut Pro XML File” format.”
    Is this a joke?
    I’ve done this as both mono track and stereo mix.
    These are the steps in the Soundtrack Pro User Manual.
    Guidance Appreciated.
    Mark
    Mark Hubert replied 16 years, 4 months ago 1 Member · 2 Replies
  • Mark Hubert
    May 23, 2010 at 3:41 am
    OK….
    I just went into FCP and Import XML chose the mastermix.xml file and it worked.
  • Mark Hubert
    May 23, 2010 at 4:47 am
    And now FCP is totally unstable and crashing when I do import the XML.
    It creates another sequence with the old tracks disabled (as the UM says it does) Start working with it and it crashes.
