Activity › Forums › Apple Final Cut Pro Legacy › FCP Bugs? rendering and playback problems
  • FCP Bugs? rendering and playback problems
    Posted by Lokifilm on July 19, 2005 at 12:09 am
    anyone else seeing these problems??
    I have a NTSC standard def project based on quicktimes I created from still image
    sequences. The frame sizes are quite large: 2048 x 1536 rendered at 29.97 and then
    scaled down in FCP to fit in a normal D1 frame. In FCP 4.5, all I had to do was “render
    all” and the whole edited timeline was re-rendered in about 20 minutes (its 5:45 TRT).
    In FCP 5, the progress bar creeps along for 15 minutes then disappears without
    leaving behind one single chunk of rendered material! However, if I select an individual
    clip, or a section of up to 10 clips, they render fine! Any more than about 10 clips, and
    I get the same results as before (progress bar, waiting, and nothin.) Changing the codec
    to something besideds photoJPEG or uncompressed 8-bit has no efffect. Anyone seen this
    problem?
    Also, I notice that on my system if I am playing content from the keyboard from a
    sequence, hitting “J” after pausing with “K” will crash it everytime.
    My setup:
    Dual G5 2.5, with 2.5 GB ram, Blackmagic Decklink HD Pro card running 5.x driver,
    FCP 5.0.2, and OS X 10.4.2. Content: PhotoJPEG quicktimes running at 18 – 27 mb/sec
    but (hopefully) rendered down to 720 x 486 uncompressed 8 bit, or alternatively
    photoJPEG at D1 rez.
    David Bogie replied 21 years, 2 months ago 2 Members · 1 Reply
  • David Bogie
    July 19, 2005 at 8:28 pm
    THese are not good symptoms.
    I’d suggest you clone your drive and then reinstall FCP. I’ve heard it can be installed right over the exising version but, frankly, I haven’t tried a reinstall.
    I’m suggesting you clone your drive just so you’ll have a back up of everything.
    I’m suddenly VERY interested in having clones of my system drives.
    bogiesan
