Activity › Forums › Apple Final Cut Pro Legacy › FCP breaking FX1 HDV footage TC
Posted by Harry Courniotes on February 26, 2008 at 4:36 pmI have notice while loading my HDV footage shot on my sony FX1 that when you load footage it is impossible to load a whole tape without timecode breaks unless you NEVER stopped record throughout the entire tape.
I do not see the timecode break while viewing the timecode on the camera LCD… Why is final cut seeing a break when I cannot?THANKS!!!
Harry Courniotes replied 18 years, 7 months ago 4 Members · 5 Replies -
Zane Barker
February 26, 2008 at 6:38 pmThey are not time code breaks. You should educate yourself about the format you are working with. Because HDV is MPEG based video, it has a GOP structure. The GOP or group of pictures has 1 full frame or iFrame, all other frames do not contain full information and are based off of the iFrame.
FCP by default breaks HDV video each time you start and stop the camera because the last GOP is not always a full GOP.
I believe that there is a way to turn it off (if you search the forums I am sure you will find it) I personally like it so I do not turn it off.
Don’t let technology get in the way of your creativity!
David Roth weiss
February 26, 2008 at 6:51 pm[Zane Barker] “I believe that there is a way to turn it off”
Yeh, by dubbing the tape to another with continuous timecode.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Zane Barker
February 26, 2008 at 7:19 pm[David Roth Weiss] “Yeh, by dubbing the tape to another with continuous timecode.”
That may be the case, like I said I actually like how FCP does that, so I have NEVER looked for a way to turn it off.
Eric Hansen
February 26, 2008 at 7:40 pmif you are capturing HDV direct through Firewire “Start/Stop Detect” is on by default. this will make a new clip with every start/stop of the record function. it rocks.
to turn it off, go to the Log and Capture window, open the Capture settings tab, and un-check Start/Stop Detect.
this feature only works when in DV or HDV firewire capture mode. Start/Stop Detect isnt available under the other Easy Setups.
e
4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
Quantum SDLT600A
decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots
