Activity Forums Apple Final Cut Pro Legacy FCP blade tool/ ctrl-v command
  • FCP blade tool/ ctrl-v command
    Posted by Nicholas Vanvoorthuysen on April 20, 2013 at 4:39 pm
    Hello,
    I have a weird thing happening in a timeline:
    Using the shortcut ctrl-v to slice (with NOTHING highlighted/selected), it only cuts the audio. Usually I use it to slice everything at once OR a selection. This is really slowing down my workflow as I’m used to using this command.
    So, I’m going through footage and slicing, and I have to double-edit every cut, first the audio, then select the video clip and slice that above it over the audio edit.
    anyone had this problem before? Some weird setting I accidentally hit?
    Thanks.
    Nicholas Vanvoorthuysen replied 13 years, 4 months ago 3 Members · 4 Replies
  • Daniel Sametz
    April 20, 2013 at 5:28 pm
    To cut you need to use b not v. Doble b cuts everthing in the vertical line not just one clip.
  • Nick Meyers
    April 20, 2013 at 10:12 pm
    “Some weird setting I accidentally hit?”
    probably Auto-select is turned off in the relevant video tracks.
    thats the tiny dark grey buttons left of the timeline
    Command Zero will toggle AUtoselect on all video tracks.
    Command 1-8 on specific V tracks
    Option Zero, OPtion 1-8 for audio tracks
    nick
  • Nicholas Vanvoorthuysen
    April 21, 2013 at 4:19 pm
    no, control-V cuts everything that the timeline marker is on without having to click the mouse. I prefer to use control-V over B because it’s faster for me to not use the mouse.
    My question was answered below though, the issue was that the auto-select was accidentally off for the v1 track. Now I can control-V slice til the cows come home!
    April 21, 2013 at 4:21 pm
    Thanks so much, that was the problem, auto-select.
