Activity › Forums › Apple Final Cut Pro Legacy › FCP Batch Capture
  • FCP Batch Capture
    Posted by Earle Nichol on October 5, 2007 at 9:53 pm
    Hey Guys,
    quick question. We have just jumped into the world of FCP making the transition from AVID. We have a sequence that was archived. Now we need to do a credit change that has shots associated with the credits. We only want to redigitize the 9 clips on the credits, but when we select the clips and try to batch capture, FCP wants to capture the entire source clips that our timeline clips came from. Which steps am I forgetting. AVID does decompose, & I thought making the timeline clips independants would work but…no dice.
    thanks
    Ernie Geefay replied 18 years, 2 months ago 3 Members · 3 Replies
  • Russell Lasson
    October 8, 2007 at 4:16 pm
    It sounds like those clips are subclips that you’re trying to digitize. Meaning, they reference one larger clip. You’ll need to trim the clips before you digitize them using Media Manager. Here’s what I would do:
    – Select the clips that you need.
    – Select File – Media Manager
    – Select Create Offline from the pulldown menu
    – Select the Codec that you want the new sequence to be in
    – Select Delete unsude media
    – Add one second handles
    – Select OK
    This will create a new project with the clips you’ve selected. It will also change the clips from subclips to master clips. Now you can copy the sequence back into your other project and batch capture.
    -Russ
  • Earle Nichol
    October 8, 2007 at 10:31 pm
    Hey Russ,
    Thanks for the response, it’s Thanksgiviing here in Canada, I’ll give it a shot when I get back to the office tomorrow.
    Thanks again!
    pearl
  • Ernie Geefay
    July 19, 2008 at 5:13 pm
    I gave this a try and it works
    The only suggestion is when you go FILE>Media manager make sure to UNCHECK “include master clips outside selection”
    Correct me , anyone, if I am wrong
    Ernie
