Activity Forums Apple Final Cut Pro Legacy FCP-Avid m2t
  • Posted by John Simboli on April 11, 2008 at 12:51 pm
    Avid loads m2t files from CF card with time code. Is there a way for me to load the same m2t files from CF into FCP so that FCP works with same time code as Avid? My goal is to off-line on FCP (older G4 system currently running FCP 4.5, but can upgrade if necessary) and conform edit on Avid.
    Neil Patience replied 18 years, 5 months ago 3 Members · 2 Replies
  • Shane Ross
    April 11, 2008 at 2:45 pm
    FCP doesn’t edit m2t files…and the only way it can is if you convert with MPEG STREAMCLIP, in which case whatever timecode is lost…so this isn’t a viable solution.
    The Avid software is cheaper now, so you can offline and online on that if needed.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Neil Patience
    April 17, 2008 at 12:48 am
    Hi Guys
    Sony does have a plug-in that allows you to use M2T files with the log and transfer tool.
    M2T and DVCAM/DV files stored on the HVR-DR60 and the CF card of the Memory Recording Unit can be imported correctly to your Final Cut Pro 6 project by installing the Sony Recording Unit Plug-in software.
    This software allows the video and audio stored on these devices to be transferred into Final Cut Pro using the Log and Transfer feature.
    It is available here
    However I tried to install it on my MBP running OS X 10.5.2 and FCP 6.0.3 and it fails to find FCP on my system.
    As such it wont install, giving me a message along the lines of “cant install, you need to have FCP 6.0.2 already installed on your system”
    I have everything in default locations so not sure why it cant find FCP in my case.
    Anyway maybe someone else can give it a go.
    best wishes
    Neil
