Activity › Forums › Apple Final Cut Pro › FCP AV OUTPUT
FCP AV OUTPUT
Posted by Guy Crossman on September 10, 2023 at 9:06 amI am not sure if FCP can see the Black Magic box I have attached to my Imac to get video output. A/V Output is grayed out, and if I go to Playback in Preferences, there is no mention of Black Magic under GPU. Any ideas? Thanks
Jeremy Garchow replied 2 years, 12 months ago 4 Members · 5 Replies -
Eric Santiago
September 11, 2023 at 12:32 amGoing to need more info than Black Magic Box.
Which unit? Which version of Blackmagic DesktopVideo are you running?
How are you connecting to the unit?
Operating system etc….
Guy Crossman
September 11, 2023 at 8:19 amHi Eric, I’ve got FCP 10.5 on an Imac running Catalina 10.15.7 connected via Thunderbolt to a Black Magic AMA Radeon Pro 580 . Thanks Guy
Mads Nybo jørgensen
September 11, 2023 at 8:48 amHey Guy,
This might sound silly, but I had this come up recently:
Are you using a Thunderbolt cable between the iMac and the Blackmagic eGPU?As in many external SSD drives only ships with a USB C cable.
And, if you in passing have grabbed one of those, the Mac may not see the Blackmagic.Atb
Mads -
Guy Crossman
September 12, 2023 at 7:53 amAh.. Thanks MAds I will check it out, I’m not sure which it is, I think Thunderbolt but will look
Thanks again Cheers Guy
