Activity Forums Apple Final Cut Pro Legacy FCP Automation
  • Posted by Donald Mitchell on August 2, 2005 at 11:35 am
    I have a very long project with thousands of small clips for created for an art installation. I need to slightly enlarge each clip and nudge it left by a few pixels. Is there any way to automate this in FCP HD in the same way Photoshop might record an action, or can I do this with Automator in OSX Tiger, or is there another solution that will avoid advanced RSI setting in?
    Mitch
    Donald Mitchell replied 21 years, 1 month ago 5 Members · 5 Replies
  • Andy Mees
    August 2, 2005 at 12:03 pm
    Hi mitchino
    sadly theres no built in automation for FCP, no applescript or Automator support either … you could have a go at creating something that uses FCP’s XML or EDL support but its not for the faint hearted. if you have programmming skills (or access to someone who does) then it may be worth looking into.
    perhaps enlarging and nudging one clip, then saving that as a favourite motion might be the answer? (choose Effects > Make Favotite Motion / or press control-F)
    you could then select all the other clips in the timeline and apply the same motion to all
    check out the manual: vol III, chapter 13, pg 281
    cheers
    Andy
  • Steve Eisen
    August 2, 2005 at 12:33 pm
    You can use copy and paste attributes if the enlargements and shifts are identical.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 2.45 TB External Stor
  • Tom Matthies
    August 2, 2005 at 1:07 pm
    If the adjustments are all the same for all the clips, just edit them into your timeline, adjust the first clip to your liking, copy the attributes (CMD-C), highlight the rest of the clips, (double right facing arrows) and paste (OPTION-V) the motion attributes into the rest of the clips. Fast ‘n easy.
    Tom
  • David Chai
    August 2, 2005 at 1:16 pm
    If it’s all of them, then just nest them and then apply the change to the new nest.
  • Donald Mitchell
    August 3, 2005 at 7:29 pm
    Thanks to all. Using a motion favourite worked great.
    Mitch
