Activity Forums Apple Final Cut Pro Legacy FCP audio to CD question
  • FCP audio to CD question
    Posted by Saya Hillman on April 27, 2005 at 8:45 pm
    I want to burn some FCP audio tracks to CD. I plan on converting them to AIFF in FCP and then using iTunes to burn the CD. Is there a way I can insert tracks every 5 minutes or so, like a DVD’s chapters, so the CD is easy to search?
    Saya Hillman replied 21 years, 5 months ago 2 Members · 2 Replies
  • Jeff Carpenter
    April 27, 2005 at 9:00 pm
    You’ll have to break the audio up into seperate tracks. Export your audio in multiple 5 minute chunks and then put them on the CD in the correct order. Remember to go into iTunes’ prefrences (BURNING) and set the gap between audio tracks as “none.”
  • Saya Hillman
    April 27, 2005 at 10:13 pm
    Thanks, worked perfectly! I appreciate it.
