Activity › Forums › Apple Final Cut Pro Legacy › FCP audio playing through… Itunes?
Posted by Brad Mirman on May 1, 2010 at 7:08 pmJohn Fishback replied 16 years ago 2 Members · 1 Reply -
1 Reply
John Fishback
May 4, 2010 at 4:59 pmThe audio should be 48kHz, 16 or 24 bit PCM. You should use an external program like Soundtrack Pro or QT Pro to convert your 44.1kHz audio to the above specs. Then import that track and merge to your video. Then, when you look at it, it shouldn’t be showing iTunes, and the audio specs should appear properly lower in the properties window.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
