Activity › Forums › Apple Final Cut Pro Legacy › FCP Audio Out Of Sync
Posted by Mike Puleo on May 30, 2010 at 6:23 pmFor some reason when I play my footage in the time line the audio goes out of sync. When i pause and then resume from current location audio is back in sync. Any ideas on why this happens and how to fix it.
Mike Puleo replied 16 years, 4 months ago 4 Members · 4 Replies -
John Fishback
May 30, 2010 at 9:47 pmWe need more info: what computer, version FCP, drives, codec of footage, your sequence settings.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Daniel Ludwig
May 31, 2010 at 6:47 amHi,
if you have used a real-time-effect on any of your clips on the timeline this could happen. please have a look if you have a green line on top of your timeline – that is showing a realtime-effect is used.cu
danny
Steve Oakley
May 31, 2010 at 6:30 pmwhere are you comparing audio sync ? for example, any video I/O card will have several frames of delay between its own outs and the computer monitor. however, audio should be in perfect sync with the video cards outs.
if you are looking at computer monitor and computer audio out, it should be good.
very first thing to do is trash FCP prefs and it will probably be fixed.
if that fails, the very next thing I would check is the source material. if thats good –
you need to be more specific about your hardware / source materail / what you are doing with the clips on the TL.
Steve Oakley
DP • Editor • VFX Artist
http://www.practicali.com -
Mike Puleo
May 31, 2010 at 7:14 pmhey everyone thanks for you help i figured it out – just had to add a slug into spots w/o footage. im surprised it was that easy
