Activity Forums Apple Final Cut Pro Legacy fcp and x11?
  • Posted by Baba Goof on January 6, 2007 at 11:37 pm
    there are a couple of apps i’d like to run on my fcp system
    that require x11 (openoffice, gimp). how does this work
    with final cut? would i just run fcp under x11? would i have
    to switch between aqua and x11?
    my setup is three monitors for working, the left and center
    would be for fcp, but i’d like to keep the right monitor open
    for use with peripheral apps like openoffice or gimp. it
    would be great to be able to have both fcp and one or both of
    these others open and running at the same time.
    thanks,
    BabaG
    Baba Goof replied 19 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Debe
    January 7, 2007 at 12:21 am
    X11 runs alongside OSX. Some of the more techno-minded here might be better suited to explain how that works. I just know it does.
    Provided you have sufficient RAM, you can have FCP running as normal under OSX, and have GIMP open as well in X11. I’ve done it successfully many times.
    debe
  • Joe Paolo
    January 7, 2007 at 12:35 am
    Neooffice is an opensource OSX native app ported from openoffice. Works great in 10.4.8. Not sure about Gimp and others, but check the open source web sites. A lot of opensource stuff is getting portted to OSX with mixed success. I tried Scribe (page layout) for OSX. It was pretty sluggish.
    joe
  • Debe
    January 7, 2007 at 12:36 am
    Hi, Joe!
    deb e
  • Joe Paolo
    January 7, 2007 at 12:40 am
    Howdy. Didn’t relize debe was debb.
    joe
  • Debe
    January 7, 2007 at 12:45 am
    Sounds the same, doesn’t it!!
    debe
  • Baba Goof
    January 7, 2007 at 1:23 am
    tried neooffice a while back. it’s a bit funky, or was then.
    the openoffice folks are working on an aqua version of ooo
    but says on the site it’s still a couple of months off so
    who knows.
  • Arnie Schlissel
    January 7, 2007 at 5:06 am
    There’s no conflict between X11 & FCP. You should install X11 from your Panther or Tiger install disk. Make sure that the version of X11 matches your version of OS X.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Baba Goof
    January 7, 2007 at 9:46 pm
    system just came with 10.4.7. i updated to 10.4.8. is a 10.4.8 x11 version necessary
    or will any 10.4 x11 work?
