Activity Forums Apple Final Cut Pro Legacy FCP and Video Assist operator system?
  • FCP and Video Assist operator system?
    Posted by Thomas on May 17, 2005 at 11:16 am
    Does anyone know if Final Cut supports video assisst?
    Basically, I’m going to to be on a show with Two film cameras and I need to figure out how I can do real-time capturing and editing with
    a G4 laptop using Final Cut Pro.
    I believe FCP 5 has multi-cam editing as well?
    Ben Ruffell replied 21 years, 4 months ago 3 Members · 2 Replies
  • Peter Mcauley
    May 17, 2005 at 12:56 pm
    You can only capture one feed at a time. You would need a second system to capture the second camera at the same time. Then move you capture files back to the first system for editing.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Ben Ruffell
    May 18, 2005 at 6:14 am
    I am very interested in setting up aa Apple based video assist system.
    I was wondering if anyone was successfully using such systems?
    I have been considering cheap, simple set ups – such as an imac G5 20″ mounted in a stormcase with firewire drives, capture card and video distribution amp.
    Any thoughts out there?
    Ben Ruffell
    Camera Assistant etc
    http://www.compositepictures.com
