Activity › Forums › Apple Final Cut Pro Legacy › FCP and transcribing
  • FCP and transcribing
    Posted by Geralyn Abinader on July 26, 2010 at 6:48 pm
    first, I’ve already searched and haven’t found the answer I want. Thanks.
    I need to view the clips (or listen to them) and be able to type at the same time. There seems to be no easy way to do this in FCP nor is there anything in the manual.
    I got MacSpeech Scribe and can’t figure out how to edit their bad transcription. It would actually work, if after it transcribed a clip I was able to playback audio and make corrections. But it doesn’t work like that. (out $100)
    And so I’m back to FCP. I have digital files imported from a P2 card. I have also exported the files as .aif files. If anyone has any ideas I’d be happy to hear them.
    Geralyn
    Rob Tinworth replied 16 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Bret Williams
    July 26, 2010 at 6:56 pm
    Open the aifs or QTs in QTPlayer and press play. Go back to word or whatever software you’d like to use and start typing.
    Bret Williams
    Web Design . Motion Graphics . Video Editing
    http://www.bretwilliams.com
  • John Fishback
    July 26, 2010 at 7:18 pm
    Checkout pgs 21 & 22 in the manual. It might help you out. Also, there may be foot pedal available to control playback. Check with tech support about that.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Geralyn Abinader
    July 26, 2010 at 7:47 pm
    thanks to you both for the ideas. I’ll check them out. best, Geralyn
  • John Doggett-williams
    July 26, 2010 at 11:02 pm
    My solution was this: set up a separate laptop/computer to transcribe on,that way you can pause the footage rather than having to switch apps all the time, it also meant you could type at your own pace. Even better if you have someone sitting next to you who could control FCP.
    I also applied a timecode generator from the effects bin onto the selected clips, seeing large type TC at a glance made life a lot easier.
    John doggett-williams
  • Geralyn Abinader
    July 27, 2010 at 12:35 am
    thanks, this is a good idea too. Not sure I’m sure how the tc effect works, but I’ll check it out. Thanks. Geralyn
    Geralyn
  • Patrice Freymond
    July 27, 2010 at 5:43 pm
    Zeit Anker, maker of a great subtitling application named Annotation Edit, bundles it with Annotation Transcriber which is just what you may be looking for.
    Download the demo of AE and you will be able to use AT since it is free software.
    Hope this helps,
    Patrice
  • Rob Tinworth
    July 27, 2010 at 6:36 pm
    I’d second the second laptop approach. As an added bonus you can then use a wireless keyboard as a foot pedal.
    Rob Tinworth
    http://www.1021.tv
