Activity › Forums › Apple Final Cut Pro Legacy › FCP and Sony Z1 HDV compatible?
Posted by Nigel on July 11, 2005 at 1:47 pmCan I use the Sony HDV Z1 with Final Cut Pro HD?
Keith Hill replied 21 years, 1 month ago 5 Members · 7 Replies -
Jerry Hofmann
July 11, 2005 at 1:55 pmThe short answer is No.. but you could use it with FCP 5.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Nigel
July 11, 2005 at 2:12 pmThanks Jerry. Will it work natively with FCP5 then, or do you still need something else? I didn’t know if Apple had native support for HDV yet?
Jadranko Gudan
July 11, 2005 at 2:20 pmFCP5 is fully compatible and supports HDV format with no obvious problems.
We have Z1 for some time now and FCP studio which came about a week ago and everything works fine with not much rendering and/or problems.
Hope that this answers your question,
Jadranko -
Peter Sassi
July 11, 2005 at 4:45 pmJust a note, if you can, use a G5 HDV seems very sluggish on my G4 1Ghz. Especially if you use filters.
-peter
Keith Hill
July 12, 2005 at 12:04 amI have a question for you since you have a Z1. I have to use one with other cameras (a DVX100A and a JVC DV5000) this weekend in a test situation. It’s unavoidable and I need to formulate a plan for using the cameras together. I was thinking of using the Z1 just straight DV – 4:3, instead of trying to do the HDV thing with the other formats. I really like shooting 23.98 (24p) with the DVX, but am uncertain about the workflow if I incorporate this workflow to include the Sony and JVC. Any ideas, or have you dealt with something like this before and can recommend a direction? It’s a live concert environment.
Keith Hill
https://www.LightedPath.biz
Dallas, TX
Final Cut Studio, Combustion (v3.0.4), DVD StudioPro 4 (v 3.0.2); MAC G5 (v10.4.1-Tiger) 2Ghz, 1.5 RAM -
Jadranko Gudan
July 12, 2005 at 9:41 amWell, the only question is which is your final format? Is it SD or HD? As far as I can see it is NTSC, right?
If you plan to do all in DV then use DV on Z1 also. But we tested all three modes of Z1 and found that DVcam mode is superior (at least for some stuff we shoot and finalize everyday) as it requires a bit less postprocessing then DV mode. Maybe it is not a bad idea for you too. Try to shoot something in DV and DVcam and compare it.
Hope that this will help you,
Jadranko -
Keith Hill
July 12, 2005 at 1:28 pmThanks. I will follow this advice. I can capture DVCAM directly from the Z1 if I’m noy mistaken.
Keith Hill
Dallas, TX
