Activity › Forums › Apple Final Cut Pro Legacy › FCP and PSP
FCP and PSP
Posted by Abram Corbett on April 25, 2007 at 6:35 pmAnyone had experience with creating video for the PSP? Links to sites, or articles?
Abram Corbett replied 19 years, 5 months ago 3 Members · 5 Replies -
Don Greening
April 26, 2007 at 8:44 amI just watched a short demo on Episode Pro and this program actually has a Play Station Portable compression preset. So I’m assuming that you do your edit the same as anything else in FCP but when you’re done you just port your self-contained or reference .mov over to Episode and choose the psp preset. Episode Pro is brought to you by the good folks at FlipForMac and with that program you can even have those presets available in Apple’s Compressor if you tell Compressor where to find them first. Perhaps Episode Pro will have that same feature.
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
Todd Beabout
April 26, 2007 at 4:11 pmYou can use ffmpegx to turn any movie out of Final Cut (or any program for that matter) into PSP format. And it’s a free download.
-Todd Beabout
Vazda Studios -
Abram Corbett
April 27, 2007 at 2:37 amYeah I tried this program and the quality was not that great. Perhaps I need to spend some time with setting to tweak the quality. The PSP preset is what i used and was pretty dissapointed.
“What we do in this life echoes in eternity”
Todd Beabout
April 27, 2007 at 2:00 pmYeah, it is pretty easy to tweak the settings. If your video is not looking the best, click on the “Video” tab (next to “Summary”) and you can adjust your Video Bitrate which should help in the quality. It also has a bitrate calculator of sorts built in, where you can target a specific file size, or see what the file size would be a a given bitrate.
I’ve had decent results with that program, but it did take some adjusting.
-Todd Beabout
Vazda Studios -
Abram Corbett
April 30, 2007 at 11:20 amThank you for the input. I will try these ajustments.
