Activity › Forums › Blackmagic Design › FCP and Premiere on Same System – No Presets in Premiere?
Posted by Peter Corbett on November 10, 2009 at 10:53 amJust commissioning a new Mac pro that has Final Cut and CS4 on it. The card is a Decklink HD Extreme, FCP works okay with the drivers but no Blackmagic presets show up in Premiere. Do I have to manually copy the drivers to PPro somehow?
PeterPeter Corbett
Powerhouse Productions
http://www.php.com.auPeter Corbett replied 16 years, 6 months ago 4 Members · 6 Replies -
Aristides Tiropolis
November 10, 2009 at 1:37 pm[Peter Corbett] “Do I have to manually copy the drivers to PPro somehow?”
No you don’t. For some inexplicable reason, Blackmagic chose not support CS4 on the Mac but only on Windows.
Joshua Helling
November 10, 2009 at 7:51 pmHey there,
The reason is actually not inexplicable at all. There is a very clear reason. When CS4 launched there was (as I am sure that most of you are aware) there was no hardware support until after the launch.
When the hardware vendor support was added we worked hard for several months (with Adobe) to make the new interface work correctly. The media core part of the Adobe suite was choking our boards.
To put a point on it, the Windows side wasn’t even fully optimized and had problems on some systems. Because of this, and the time we spent working on getting the PC version working right (our then only editor on the PC), we didn’t have enough time to get the Mac version running properly. Now, after many more months the issues were corrected (with Adobe and BMD working very closely) in 4.2.
So in a sense the 4.2 update has allowed us to get the plugin interface in a good enough position to start working on the Mac version. I would expect to see one in the near future (read, a month or so).
Short answer, we didn’t drop it for no reason, and we are in a position to work on the Mac version now.
Sincerely,
Joshua
Director of Support
Blackmagic Design Inc. -
Peter Corbett
November 10, 2009 at 8:38 pmGawd. I didn’t realise that when I crossgraded my Win/CS4 to Mac/CS4.
Thanks for the heads up Joshua. I guess I’ll just plow on with Final Cut for now.
Peter
Peter Corbett
http://www.php.com.au -
Aristides Tiropolis
November 11, 2009 at 7:30 amThanks for making the effort to at least explain the technical reasons in not making BM functional on CS4.
I think you should have this sort of explanation on your website in the support library as well as in the product page in maybe another form, It could be in the vain of: “CS4 support for Mac platform is coming…” or something of that sort.
Cheers.
Carey Dissmore
February 24, 2010 at 12:12 amLong time an FCP/Multibridge Pro user, I’ve just taken on a Premiere Pro project for ‘finishing’ and I’m shocked, I mean really shocked that I can’t get my Multibridge Pro to display this project on my grading monitors.
I guess I always just assumed the support was there. Above we see Joshua stating, on Nov 10, about a month to go. I just installed the latest Multibridge drivers (7.5.2) and I have no support. It’s been 3.5 months since he last said that.
What is the status? This is suddenly a critical need for me.
All the best,
Carey -
Peter Corbett
February 24, 2010 at 12:54 amI had to quickly replace the HD Extreme with a Kona LHe when we commissioned our Mac. But I must say, I haven’t had much suceess with the AJA CS4 plugin either. I think the problems goes back to Adobe, as I find output not near as solid as with the AJA and FCP7.
Peter Corbett
