Activity Forums Apple Final Cut Pro Legacy FCP and NTFS
  • Posted by Steven Ware on August 28, 2007 at 9:31 pm
    I have been using a PC to offload my p2 cards in the field. I have the NTFS drives back in the edit but i cannot transfer all of the files to quick time. If a given folder has 5 clips only 4 show up in the log and trans window. For every contents folder i have there is always one or two mxf files thaat are missing. its like fcp doesnt see them.
    i have double checked that the files arent corrupt. contents folder was never changed and has the lastclip file with it.
    i have done a fresh install of fcp and quicktime. going to try reinstalling the operating system next.
    called apple and they are saying that it is the ntfs file system. but the computer reads the drives fine. have read of others using this workflow and it works for them. my test had it working.
    any ideas.
    John Fishback replied 19 years ago 5 Members · 4 Replies
  • Ernesto Sanchez
    August 28, 2007 at 9:52 pm
    For chuckles and grins see if P2 Logger Pro can see the clips.
    Ernesto Sanchez
    ProMax, Inc.
    E: ernesto.sanchez@promax.com
  • Sean Oneil
    August 28, 2007 at 10:14 pm
    Could be anything. What happens when you copy a file to an HFS disk, and then try importing it?
  • Jason Lyons
    August 29, 2007 at 3:38 am
    May want to try loading MacDrive on your PC, then mounting a Mac drive on the PC then copy the media to the Mac formatted drive, unmount from PC and try back on the Mac. You could also try file sharing via SAMBA services over Ethernet.
    j
  • John Fishback
    August 29, 2007 at 2:08 pm
    Is it possible that FCP is seeing two spanned clips as one? Have you tried importing all the files you can from a contents folder and seeing if all the footage is there?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
