Activity › Forums › Apple Final Cut Pro Legacy › FCP and JVC Pro HD 25p
Posted by Cem Yildirim on July 28, 2007 at 12:34 amI have some footage shot on JVC pro HD cam HDV 25p. I use FCP 5 but it does not have a set up for HDV 25 p. Is there any way that i can edit 25p HDV footage in FCP 5. Thank you.
Tom Wolsky replied 19 years, 1 month ago 4 Members · 5 Replies -
Dan Silber
July 28, 2007 at 12:40 pmBe sure you have at least FCP version 5.1.2
Choose “HDV 720p25” for capture and as a sequence preset.
If you encounter the problem if erratic clip “shredding” during capture, you may need to update your JVC firmware.
From JVC: “Certain NLE’s (ie Final Cut Pro) have experienced issues with scenes being broken into shorter segments (clips) during capture. This upgrade addresses this issue.”
https://pro.jvc.com/pro/special/HD100_upgrade/hd100_upgrade_faq.html#ques11a
Apparently, you need to have at least:
GY-HD100/101: 16-04 oder 19-03 oder 04-01
GY-HD110/111: 01-03
BR-HD50 01-06Good luck!
Cem Yildirim
July 28, 2007 at 5:54 pmThanks. However There is no such set up as “HDV 720p25” in FCP. Thats the issue I guess.
Deleted User
July 29, 2007 at 1:43 amHello,
We updated Final Cut Pro 5.0 the other day and in the presets we have access to the HDV 720p 25 setting. Have you tried doing a MAC update via the internet?
Leo
Cem Yildirim
August 2, 2007 at 12:46 pmWhat version to upgrade? I got 5.0.4 and it seems to be the last free upgrade avaliable for 5.0
Tom Wolsky
August 2, 2007 at 12:57 pmYou cannot work with 720p25 without a newer version of FCP.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
