Activity Forums Apple Final Cut Pro Legacy FCP and Jes Deinterlacer
  • FCP and Jes Deinterlacer
    Posted by Melanie Bartley on March 7, 2011 at 10:27 pm
    Hello,
    I would really appreciate some help with this. I used a Canon 500D for a short video. This camera records 1920×1080 at 20fps, which is ridiculous. I downloaded Jes Deinterlacer to convert the clips to Apple ProRes 422 (HQ) with the same dimensions, at 29.97 fps. Everything looks fine on QT, but when I import it into FCP the image gets squeezed into a vertical rectangle. Has anyone had the same issue? Please help!
    Melanie Bartley replied 15 years, 6 months ago 2 Members · 2 Replies
  • Matt Killmon
    March 8, 2011 at 1:05 am
    Not directly related, but I did have a situation like this where I shot a video with a Canon T1i at 1920 x 1080, not realizing it was limited to 20fps at that resolution. Imagine my shock when I imported the file and noticed how juddery it was! Fortunately the clip in question was very low-motion (shot of a talking head, done handheld but pretty smoothly), and I was able to use the Optical Flow image retiming in After Effects to boost it artificially to 24fps (didn’t feel like pushing my luck to 29.97). It ended up working out—the few weirdo motion artifacts were so minor as to be unnoticeable in realtime, and no one said a word.
    Depending on the nature of your clip (and, obviously, if you have After Effects) this might be a good way to go.
    The initial convert is probably best done in QuickTime Pro, honestly. Dave, how is MPEG Streamclip for duties like this? I’ve never used it as a general purpose video converter, just for situations where I needed to go from an MPEG-2 source.
  • Melanie Bartley
    March 8, 2011 at 1:24 am
    Thanks, Matt. Like you, I hadn’t noticed the camera was shooting at 20fps. I actually re-started my computer and JES Deinterlacer, converted the files to Apple ProRes 422 at 29.97 and it worked perfectly!
