Activity › Forums › Apple Final Cut Pro Legacy › FCP and HQ images
  • FCP and HQ images
    Posted by Yiannis Valkan on May 18, 2009 at 2:07 pm
    Hi all,
    I imported to FCP about 50 HQ JPG images. By HQ i mean 300dpi and over 3000px each.
    My problem is that FCP seems that cannot handle that kind of pictures. During playback, it flickers and changes some colors.
    When i send these images to motion, save them and get them back to FCP, it works great.
    Does anyone have any ideas why this is happening? Is Motion the ONLY solution?
    Tank you.
    2 minds are better than one.
    Tony Brittan replied 17 years, 4 months ago 5 Members · 4 Replies
  • Rob Grauert
    May 18, 2009 at 2:02 pm
    DPI has nothing to do with video. The only thing that matters is the pixel dimensions of the image. Therefore, if you are working with 720p, your jpg image needs to be at least 1280X720 pixels to fill the screen with no loss in quality. If you want to scale the image and pan to create the Ken Burns effect, then your image should be twice that of the format you are working in. So in this case, 2560X1440 pixels.
    Good Luck
    Robert J. Grauert, Jr.
  • John Fishback
    May 18, 2009 at 2:12 pm
    FCP doesn’t like very large/dense images. Reduce their size in Photoshop, or use Motion as you did, or AfterFX. If you want to stay with FCP, try rendering your jpg clip after inserting it in your timeline and adjusting keyframes, etc.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Rafael Amador
    May 18, 2009 at 2:26 pm
    And try avoiding JPEG. In the end is a compressed format. Decompress it is an extra task for FC.
    You can increase the FC’s “Still cache”. It helps when working with many pictures or big size.
    Rafael
    http://www.nagavideo.com
  • Tony Brittan
    May 18, 2009 at 5:15 pm
    I always change format to .png also. FCP likes that format!
